outatime Posted December 6, 2006 Report Posted December 6, 2006 I have a 1996 buick regal 3.8. Where is the radiator drain plug. I didn't see it at first glance and figured it would be easier to ask here before spending 5 minutes looking for it. Quote
Robby1870 Posted December 6, 2006 Report Posted December 6, 2006 It's on one of the bottom corners. Mine's on the driver's side. Quote
FordBoy Posted December 6, 2006 Report Posted December 6, 2006 So is mine a small black plug. EDIT: make sure you check the "O" ring. Quote
5speedz34 Posted December 6, 2006 Report Posted December 6, 2006 Drivers side of the radiator at the bottom of the tank. Quote
outatime Posted December 6, 2006 Author Report Posted December 6, 2006 EDIT: make sure you check the "O" ring. Do you mean the o ring for the drain plug ? Quote
outatime Posted December 6, 2006 Author Report Posted December 6, 2006 Thanks for all the replys. I need to replace the radiator it has a small leak that is small enough not to see but big enough to make it leak. I'm eventually going to pull it out and have it repaired at a radiator shop but in the mean time I need to add some antifreeze. I have been just adding straight water and I park it in the garage but just in case I have to leave it out I don't want to have any problems. Quote
joey b Posted December 7, 2006 Report Posted December 7, 2006 Is there a way to open these when they are stuck shut? I've broken 2. Quote
Savage Messiah Posted February 13, 2007 Report Posted February 13, 2007 Is there a way to open these when they are stuck shut? I've broken 2. yea... drain it outta the lower radiator hose instead Quote
outatime Posted February 13, 2007 Author Report Posted February 13, 2007 I forgot all about this post. I did take my radiator out and there was a lake caused by one of the fans pushing against the radiator. The shop couldn't fix it but for $120 I got a new one. When I reinstalled the fans I put a small gap in between so this won't be a problem next time. Quote
19Cutlass94 Posted February 13, 2007 Report Posted February 13, 2007 Are you sure something isnt broken on one of the fans? They should have atleast a 1/2" clearance... Quote
outatime Posted February 17, 2007 Author Report Posted February 17, 2007 Are you sure something isnt broken on one of the fans? They should have atleast a 1/2" clearance... Everything looked ok. The fans slide down on the bracket at the bottom. To get some space I slid them down but only on half of the piece that slides down if that makes sense. I double checked and everything is nice and tight and not moving and it gives me the space I need. Quote
