chadz34 Posted December 6, 2006 Report Posted December 6, 2006 For those with a 1996 LQ1, when your car is at FULL temperature, when you start your car what does it idle at immediatley? Mine seems a bit high at 1,300 or so but lowers to 800 or so within seconds, I just don't see why it has to be that high for full temperature. The mechanics had it on the code reader and EVERYTHING matches up, so they don't see it as a problem. But, rather how the car is supposed to idle. Thanks! BTW there are NO vacuum leaks and I have new head and intake gaskets. The TPS is fine too. The only thing I could come up with is a coolant temp sensor but wouldn't that throw a code? And also if it were a coolant temp sensor wouldn't my temp guage stay in the cold area? Quote
joey b Posted December 6, 2006 Report Posted December 6, 2006 my 92 with the 96 engine does the same. My 95 does not. Only idles high for about 5 seconds, but moreso when cold. Quote
Psych0matt Posted December 6, 2006 Report Posted December 6, 2006 itll idle starting around 1300, but drop down to around 800 or so withing a few seconds, and stay there Quote
chadz34 Posted December 7, 2006 Author Report Posted December 7, 2006 itll idle starting around 1300, but drop down to around 800 or so withing a few seconds, and stay there Alrighty, even when it's warm? Like, mine drops to 800 in a few seconds too, I just didn't know it was supposed to do that. Becuase my 92' just starts and drops immediately to 800. Quote
Psych0matt Posted December 7, 2006 Report Posted December 7, 2006 my thought is that maybe the computer has a slightly different startup setting in the computer? I'll check it out tonight maybe, I should start the car up anyways. Quote
chadz34 Posted December 7, 2006 Author Report Posted December 7, 2006 Alright post what you find please! Thanks! Quote
slick Posted December 7, 2006 Report Posted December 7, 2006 Every vehicle that I have ever been in, warm or cold, when you start it will be at a higher rpm, then drop(within a few seconds if warm, within a few minutes if cold). Your car is fine. Don't touch anything else that you can't fix. Quote
chadz34 Posted December 7, 2006 Author Report Posted December 7, 2006 Every vehicle that I have ever been in, warm or cold, when you start it will be at a higher rpm, then drop(within a few seconds if warm, within a few minutes if cold). Your car is fine. Don't touch anything else that you can't fix. Aiight, thanks Slick. I was just wondering if it happened to any one esle. They couldn't find a problem so I guess I'm good! Quote
Psych0matt Posted December 7, 2006 Report Posted December 7, 2006 i noticed on mine tonight, i started her up for a while since i havent driven her in over a week, i let it run for a while, idled around 850-900, revved it to about 3k slowly, and then let her back down, and she leveled off around 775-810. thought it was a little interesting, although im not surprized or anything Quote
slick Posted December 7, 2006 Report Posted December 7, 2006 i noticed on mine tonight, i started her up for a while since i havent driven her in over a week, i let it run for a while, idled around 850-900, revved it to about 3k slowly, and then let her back down, and she leveled off around 775-810. thought it was a little interesting, although im not surprized or anything Thats fine as well. I've seen some cars start at a low idle, shoot up to a higer rpm, then come back down after a bit to normal idle range as well. You both are fine. Quote
Psych0matt Posted December 7, 2006 Report Posted December 7, 2006 I didnt think I was having any problems, just posting my findings Quote
chadz34 Posted December 7, 2006 Author Report Posted December 7, 2006 One last question Slick? When I start it in the morning it kinda revvs up and down a little bit like from 1,300 to 1,100rpm I know it's not the tach cause I can hear the engine doing it. Is this normal? Becuase I have no vacuum or intake leaks. Once, warm it no longer fluctuates. Quote
5speedz34 Posted December 7, 2006 Report Posted December 7, 2006 One last question Slick? When I start it in the morning it kinda revvs up and down a little bit like from 1,300 to 1,100rpm I know it's not the tach cause I can hear the engine doing it. Is this normal? Becuase I have no vacuum or intake leaks. Once, warm it no longer fluctuates. Pretty much. Could be your TPS or IAC or something along those lines. If it goes away I wouldn't worry about it. Quote
chadz34 Posted December 7, 2006 Author Report Posted December 7, 2006 One last question Slick? When I start it in the morning it kinda revvs up and down a little bit like from 1,300 to 1,100rpm I know it's not the tach cause I can hear the engine doing it. Is this normal? Becuase I have no vacuum or intake leaks. Once, warm it no longer fluctuates. Pretty much. Could be your TPS or IAC or something along those lines. If it goes away I wouldn't worry about it. Well, I know it's not the TPS. so maybe I'll clean the IAC....oh wait I stripped the fucking screws. Thanks Tony. Quote
slick Posted December 7, 2006 Report Posted December 7, 2006 One last question Slick? When I start it in the morning it kinda revvs up and down a little bit like from 1,300 to 1,100rpm I know it's not the tach cause I can hear the engine doing it. Is this normal? Becuase I have no vacuum or intake leaks. Once, warm it no longer fluctuates. Your engine will run at a higher rpm when it's cold. It's supposed to. It's normal. Don't worry about it. Quote
5speedz34 Posted December 9, 2006 Report Posted December 9, 2006 One last question Slick? When I start it in the morning it kinda revvs up and down a little bit like from 1,300 to 1,100rpm I know it's not the tach cause I can hear the engine doing it. Is this normal? Becuase I have no vacuum or intake leaks. Once, warm it no longer fluctuates. Your engine will run at a higher rpm when it's cold. It's supposed to. It's normal. Don't worry about it. Not to contradict you but it shouldn't surge when its cold, Chris. Honestly though Chad I wouldn't worry about it. You are going to screw anything else up if you don't know what you're doing. Quote
Nicotrial Posted December 27, 2006 Report Posted December 27, 2006 mine revs up to 2000rpm and wont go down it started to do this yesterday and one of the cilinders isnt working.. i started this conversation in another topic please i need heeeeeeeeeeeeeeeeeeeeelllllllppppppppp!!!!!!!!!!!!!! Quote
