GPdriver1986 Posted June 1, 2003 Report Posted June 1, 2003 on my 91 Grand Prix there are two oil leaks. Heres a picture of where they are located. I know that the rocker cover gasket is broken because its leaking oil there. but at the back I don't know. On my engine there is an oil stain on the intake manifold in that area. Can anyone help me? Quote
per0781 Posted June 1, 2003 Report Posted June 1, 2003 gotta copy/paste the the link into your address bar to see the pic Quote
Guest Anonymous Posted June 1, 2003 Report Posted June 1, 2003 I would say both leaks are coming from the valve cover gaskets. Quote
GPdriver1986 Posted June 1, 2003 Author Report Posted June 1, 2003 http://www.geocities.com/pbpsx/00-01-09-en05change.jpg heres the picture, anyways I think both rocker covers are leaking but i'm still not sure. Quote
Robby1870 Posted June 2, 2003 Report Posted June 2, 2003 Isnt the oil sender on that side where its circled on the back? I think it is, could be that, and where EXACTLY is the oil pump drive that O-ring leaks like sob. Robby Quote
Redfox340 Posted June 2, 2003 Report Posted June 2, 2003 Isnt the oil sender on that side where its circled on the back? I think it is, could be that, and where EXACTLY is the oil pump drive that O-ring leaks like sob. Well, I know on my 2.8L, the DISTRUBOR O-RING leaked but that was on the driver side under the throttle body like the oil-pump o-ring on the DOHC. GPdriver1986, on the backside leak, is it deep down or right on the topside of the motor? If topside, I'd agree with the comments that the valve cover gaskets are needing replacement. Keep a tab on it, and if you could get / host closer pics, that will help out as well. - RedFox340 Quote
Robby1870 Posted June 2, 2003 Report Posted June 2, 2003 Well, I know on my 2.8L, the DISTRUBOR O-RING leaked but that was on the driver side under the throttle body like the oil-pump o-ring on the DOHC. Thats what I meant. Im retarded :oops: Robby Quote
GPdriver1986 Posted June 2, 2003 Author Report Posted June 2, 2003 Yes I think both rocker cover gaskets are leaking but it might have been fixed and the person that fixed it didn't wash the engine so the oil residue was left there. I will shampoo the engine and see what happens. Quote
Redfox340 Posted June 3, 2003 Report Posted June 3, 2003 Yes I think both rocker cover gaskets are leaking but it might have been fixed and the person that fixed it didn't wash the engine so the oil residue was left there. I will shampoo the engine and see what happens. Yeah, keep us posted! Simple Green does an excellent job of removing grease and grime! - RedFox340 Quote
LuminaPerformance Posted June 8, 2003 Report Posted June 8, 2003 Dont know if somebody answered this already, but i know i had two leaks on my Lumina. One was coming from the oil pump drive seal and the other was the intake. the earlier 3.1s have that problem of leaking. matter of fact the dealer i work at has a newer supreme in for the intake leak. Quote
