joey b Posted December 3, 2006 Report Posted December 3, 2006 Can anyone inform me as to how to remove the rear bumper cover? It seems to be held on by some rivets of sort that are about 3/4 inch in diameter. Quote
Crazy K Posted December 7, 2006 Report Posted December 7, 2006 sorry for the delay. front or rear? no rivets anywhere. you have to find the hidden nuts on the studs that retain either bumper. hunt around. in the rear the bottom part has two nuts on each side. one accessable from inside the trunk, one hidden from view in the fender well. Otherwise plenty of plastic pop lock things I remove with a good pair of pliers. Quote
joey b Posted December 7, 2006 Author Report Posted December 7, 2006 the rivets appeared only visible from the bottom and tucked away. They are definately in some manner fastening the bumper in place. I will have to just look better I assume. Thank you, though. Quote
1990lumina Posted December 9, 2006 Report Posted December 9, 2006 should you aren't confusing those plastic pop lock thingies with rivets?? they look somewhat similar... Quote
joey b Posted December 11, 2006 Author Report Posted December 11, 2006 one side has a square head, and I'm quite sure they are metal. I'll have to get a better look later. Quote
