fog light wiring problem found!
while investigating the wiring under my under dash panel where the trunk button is, i discovered why i smelled hot wire(while they were on) and had intermittent(spell) usage of the fog lights. the fused supply(power)line ran into a hot wire from a harness that had been spliced into. seen where it got hot and burned through the 3 way splice thing. thats just another of a few wiring hack jobs i've fixed on this. i'm running new wire, the right way! i don't really want to catch the under dash area on fire, again! :lol:
Granted I'm not good at anything with cars, but I've never had more problems than trying to install fog lights on a W. It took me months to get it right....so I hear you. Glad you figured it out!
From installing all my audio components, Ive actually learned alot about electrical and now I find it very easy. But either way, glad you got it figured out.
i found out why they had it wired to that wire. so the fogs would cut out after i turn the car off if i left them on. they would also work in the on position, too. i ran new power wire to the aux, the others are wired correctly. i'll scan the 3-way box, yikes!
