joey b Posted November 30, 2006 Report Posted November 30, 2006 Where would the water run off? It seems like it would cup up at the bottom of the top. Does it go under that piece and out along the trunk trim? Quote
Psych0matt Posted November 30, 2006 Report Posted November 30, 2006 there should be a drain inside, behind the back seat. it has a little tube that runs through the trunk to a hole in the wheel well. although ive heard different things at different places, i have that at the rear drivers side. Quote
Crazy K Posted November 30, 2006 Report Posted November 30, 2006 not all verts recieved the drain hole. some 94s and 95s apparently do not have it. but basically thats what happens, any leakage collects in the soft stow basin and slips out the drain, and down a plastic tube to below the car. Quote
joey b Posted November 30, 2006 Author Report Posted November 30, 2006 are you telling me that it is supposed to leak? If it didn't leak, where would the water leave the rear area? Quote
GnatGoSplat Posted December 5, 2006 Report Posted December 5, 2006 Mine has no drain and it doesn't leak (anymore). I don't know where the water goes, probably into the trunklid sill? Quote
Crazy K Posted December 5, 2006 Report Posted December 5, 2006 Mine has no drain and it doesn't leak (anymore). I don't know where the water goes, probably into the trunklid sill? most likely. Quote
sclary18 Posted December 8, 2006 Report Posted December 8, 2006 my drain is on the passenger side in my 92.. but.. where do you get that piece that the water drains into? Quote
Psych0matt Posted December 8, 2006 Report Posted December 8, 2006 i think im the only one ive heard of having it on the drivers side maybe a 94 only thing? Quote
Crazy K Posted December 8, 2006 Report Posted December 8, 2006 i think im the only one ive heard of having it on the drivers side maybe a 94 only thing? I want to see yours asap. one 94 i looked at had none, the one in the yard in indy I think had it on the P/s. Quote
