PCGUY112887 Posted December 6, 2006 Author Report Posted December 6, 2006 So I guess that yours doesn't rub on the back sides of the struts like mine does, huh? I just picked up some Energy Suspension bushings for the ends of the bar. Might finish the install on Friday, It has a lot of clearance on the ground, just rubbed with the car in the air. Was yours powder coated black like mine came? Too bad I scratched the hell out of it installing. Mine don't hit, and yes it was powder coated and yes I scratched the hell out of it trying to install it. I told you those bushings would work. All you had to do is hog the holes on the brackets that came with the bushings. Those bushings prevent the bar from sliding. Have fun icon_twisted I tried that, when you tried to put the bolts on then the side of the bolts would hit the rounded part of the bracket that holds the bushing and not allow the bolt to tighten anymore without really forcing it and screwing something up. The energy suspension bushings are better anyways, I may swap my hangers to them as well sometime. Quote
