If I swap my digi cluster w/column shift for an anolog cluster w/floor shift, is there anyway that I can still have a shift indicator. Without switching to a floor shifter.
Does the cluster in your parts car look like this one? Cause this one apears to have indicators on the floor and the cluster. Does it already have P R N D 3 2 1 labeled on the dash? I cant see the cluster in your for sale thread very good.
Yes, the clusters from cars with floor shift have a blank black plate where the shifter indicator would go.....2 bolts and it's out
Can I put the indicator from my Gas, Speedo, Odometer digital dash it place of the blank spot on the analog one? Or is there an indicator hidden under the plate.
your indicator will fit, the blank plate and your indicator are the exact same size and shape, so they just swap out
