chronic139 Posted May 30, 2003 Report Posted May 30, 2003 to do the oring on the 3.4, do you have to remove both the upper and lower intakes? I had the upper off tonight and it didnt create all that much more room. Quote
JS91Z34 Posted May 30, 2003 Report Posted May 30, 2003 No you do not have to remove the intakes. You can If you want it does make the job easier though. Quote
chronic139 Posted May 30, 2003 Author Report Posted May 30, 2003 do you take the crossover off then, because if not how the hell do you maneouver with such little space? Quote
JS91Z34 Posted May 30, 2003 Report Posted May 30, 2003 I know I can do it. I have little hands. the other way may be the only option you have besides taking off the X-over. Give it a shot and see. Quote
chronic139 Posted May 30, 2003 Author Report Posted May 30, 2003 so your telling me you can squeeze in that tiny space between the t-stat housing and the crossover? Quote
JS91Z34 Posted May 31, 2003 Report Posted May 31, 2003 surprisingly yeah. it was hard. I'm not saying that it was easy. Just for the hell of it, I tried to change it with everything in place and it took about 20-25 minutes to do. Quote
versache Posted May 31, 2003 Report Posted May 31, 2003 what i did was just take a gasget and slice it so it overlaps itself, then you can just turn it onto the shft. insted of acouple hours takes a couple min. versache Quote
chronic139 Posted May 31, 2003 Author Report Posted May 31, 2003 well youve convinced me enough to try. thanks for the info. Quote
Guest Anonymous Posted May 31, 2003 Report Posted May 31, 2003 surprisingly yeah. it was hard. I'm not saying that it was easy. Just for the hell of it, I tried to change it with everything in place and it took about 20-25 minutes to do. Do you have small feet, too? Quote
JS91Z34 Posted May 31, 2003 Report Posted May 31, 2003 surprisingly yeah. it was hard. I'm not saying that it was easy. Just for the hell of it, I tried to change it with everything in place and it took about 20-25 minutes to do. Do you have small feet, too? I'm a small person. I could pass as a 14 yr old. Quote
