sunroof drain locations?
so, my sunroof is leaking. i cleaned the front drains, but i can't find the rear ones. a little help please?
On a 4 door the lines run down the C-pillars and can be accessed behind the black vent things on the door jamb. Not 100% sure on a 2-door. It is really hard to get to the rear drain holes in the sunroof, so going after the end of the drain tubes might be a better idea.
it's an ste liek yours. i'll have to check the door jambs. thanks
No problem. One of my rear tubes was blocked up as well, driver's side, I think. I just took some 16ga wire and shoved it as far up the end of the drain tube as I could. Eventually gunk started coming out.
hrm... couldn't get the wire i was using to go all the way through the rear drains. possibly it was too rigid.
i did, however, run compressed air through them. i guess i'll see what happens after it rains all night tonight
I couldnt get a wire run the whole length starting from the bottom. Probably went about 1/2 way up. I just got lucky my clog was there. It's just really hard to get to the start of rear drain tubes with the glass in.
i noticed. i couldn't even see the drains. i did feel the air blowing from under the glass, though, so maybe i got them unclogged
