greencutlassdrvr Posted November 13, 2006 Report Posted November 13, 2006 ok i got my coilovers and st springs in and couldnt handle any better... but now you could hear something rattle in the back everytime i take a dip or speedbump... i double checked everything 3 times. and everything seems to be in place and tight... has this happened to any one what could it be Quote
Q-Ball Posted November 13, 2006 Report Posted November 13, 2006 Thats what is suposed to happen. They are noisey. I heard they will calm down after a few hundred miles. Quote
CSI_MuNkY Posted November 13, 2006 Report Posted November 13, 2006 Your probably just hearing the spring settle into the seat... *should* go away like Q-ball said... Mine are probably going to be noisy as hell... being that I'm making mine myself... Jamie Quote
intern8tion9l Posted November 13, 2006 Report Posted November 13, 2006 i can still hear mine make little noises. i'm not concerned Quote
TurboSedan Posted November 13, 2006 Report Posted November 13, 2006 wierd. i have no noises at all with my TDC coiloverrs and my upper spring mount is solid aluminum unlike the FFP upper spring mount that has a poly insert. the only times i have any noise at all is when the spring becomes completely unloaded and doesn't seat back into the upper spring mount correctly. this ONLY happens when i do sharp U-turns while driving up a steep driveway etc. or if i raise the car and forget to make sure the springs don't seat into the upper mount correctly. i just have to raise the car and lower it back down while guiding the spring into place OR simply drive like that for a mile or two until it 'pops' back into place by itself. but as for driving around....NO noises whatsoever. doesn't matter if i'm driving nicely or taking hard fast corners or driving on bumpy/washboard roads...they are absolutely quiet as can be. Quote
CSI_MuNkY Posted November 13, 2006 Report Posted November 13, 2006 this ONLY happens when i do sharp U-turns while driving up a steep driveway etc If thats the case it sounds like it a beefies stabalizer bar should take car of some of that extra roll, stop the spring from completely un loading. right? Jamie Quote
TurboSedan Posted November 14, 2006 Report Posted November 14, 2006 this ONLY happens when i do sharp U-turns while driving up a steep driveway etc If thats the case it sounds like it a beefies stabalizer bar should take car of some of that extra roll, stop the spring from completely un loading. right? Jamie probably would. my car has NO sway bar and no rear STB for that matter. i do have an Addco rear bar that will be going in soon (hopefully). Quote
intern8tion9l Posted November 15, 2006 Report Posted November 15, 2006 i haven't unloaded yet. i have a rear stb, but might as well have no sway bar with that stock pos in there Quote
greencutlassdrvr Posted November 17, 2006 Author Report Posted November 17, 2006 man thats good to hear... i thought i possibly did something wrong but i guess that noise is normal... yea cus i get all paranoid when i take a dip or speed bump Quote
