timing sprocket removal??
Can someone tell me how to remove the timing sprocket on the 3.4, the book i have doesnt say how to remove it and i dont want to break somthing. does it have anything to do with the cover plate on the other side of the motor or am i totally off? heres a pic just so theres no confusion on what im talking about. thanks
  • 2 weeks later...
anyone else have any ways to get this thing off? i really need to get this motor apart so i can get it hot bathed, any ideas are appreciated. thanks.
  • 1 month later...
old thread but i still havent got it off. this is the only thing stoping me from moving on so someone please shed some light on my little problem. thanks.
I used a sprocket/pulley puller and a pump clamp, because the things kept popping off since you cant get a good hold on it. I spent about 3 hours trying it normal, saw the clamp, figured id try it, and bam, came right off
pump clamp? i have co clue what that is, could you explain? or mabey a pic? thanks.
what you just clamped the sprocket and pulled it off? if so that'll be easy, thanks.
no, I had two arms of the puller on it (cant get the third on because there isnt room at the top). they kept popping off because it only had two arms on it, so i used the clamp to keep the hooks under the sprocket
