Garrett8 Posted November 4, 2006 Report Posted November 4, 2006 will calipers rotors pads etc from the newer w-bodies (gtp, monte ect) fit on a 93 z34 if i did get the calipers rotors and such? Quote
DiscoStudd Posted November 4, 2006 Report Posted November 4, 2006 You're limited to the later 1st Generation brakes. The 2nd Gen's wont bolt up at all. Here are some articles you should check out, courtesy of the main W-Body.com page: http://www.w-body.com/upgrades/brakes-rotors.html http://www.w-body.com/upgrades/brakes-rearcalipers94.html Quote
5speedz34 Posted November 6, 2006 Report Posted November 6, 2006 The only "upgrades" are putting the 94+ in the rear on (but you can't use the ebrake cable) and swapping over 96+ front strut assemblies to accomadate the bigger 11.25" rotors. Other than that you could put on goodridge brake hoses and slotted/drilled rotors. Quote
pwmin Posted November 7, 2006 Report Posted November 7, 2006 yes, you can use the ebrake cable, btw. i would just do the rear swap and get the goodridge lines with ebc slotted rotors and green stuff pads. thats what im going to do when my brakes go out again (except for the swap, of course) Quote
5speedz34 Posted November 8, 2006 Report Posted November 8, 2006 yes, you can use the ebrake cable, btw. i would just do the rear swap and get the goodridge lines with ebc slotted rotors and green stuff pads. thats what im going to do when my brakes go out again (except for the swap, of course) How did you get the ebrake cable to work? Quote
pwmin Posted November 8, 2006 Report Posted November 8, 2006 well, i did two of them for redz a while ago. iirc, on the right side side, i bent the bracket a little and took out the back two bolts that hold the cable to the frame and on the left side, i used a spacer and it worked just fine. Quote
