blkinternational Posted November 4, 2006 Report Posted November 4, 2006 tryed replaced the battery just put in a new starter checked every fuse in the car lights work sterio works when i turn the key nothing not even a click??? help plz Quote
THe_DeTAiL3R Posted November 4, 2006 Report Posted November 4, 2006 Did you check the bolt on the auxilariy terminal (positive from the battery) ? Quote
blkinternational Posted November 4, 2006 Author Report Posted November 4, 2006 yeah i checked its tight, but that post in cracked? Quote
19Cutlass94 Posted November 4, 2006 Report Posted November 4, 2006 Is there any corrosion on the battery terminals? Quote
blkinternational Posted November 4, 2006 Author Report Posted November 4, 2006 nope checked that i mean the lights work and eveything just nothing happens when i turn the key to start it, only thing that happens it beeps in the inside and the dash lights come on and blah! Quote
19Cutlass94 Posted November 4, 2006 Report Posted November 4, 2006 Does this thing have a chip in the key? Quote
blkinternational Posted November 4, 2006 Author Report Posted November 4, 2006 yeah it does. i tryed both sets of keys still nothing Quote
Regal_GS_1989 Posted November 4, 2006 Report Posted November 4, 2006 does the security light flash at all when you try start it? Quote
Regal_GS_1989 Posted November 4, 2006 Report Posted November 4, 2006 Ok. Its a VATS realated issue. More then likely, the chip reader inside the ignition is worn out. You can bypass it completely by following Kevin's writeup. http://vats.likeabigdog.com/ Quote
DiscoStudd Posted November 4, 2006 Report Posted November 4, 2006 Damn, I'm too late to shill my write-up again Another thing to try would be to put the car in Neutral and see if it will crank, but you mentioned the Security light, so give the ole "resistor trick" a try and see what happens. That site again: http://vats.likeabigdog.com Quote
SigEpCutlass Posted November 6, 2006 Report Posted November 6, 2006 Damn, I'm too late to shill my write-up again Another thing to try would be to put the car in Neutral and see if it will crank, but you mentioned the Security light, so give the ole "resistor trick" a try and see what happens. That site again: http://vats.likeabigdog.com That's your best bet IMHO. Quote
