GrandAmSE Posted November 2, 2006 Report Posted November 2, 2006 Ok I got a Front STB off a vert today and just had a thought. Does a vert have a Rear STB that will work on a Grand Prix? Quote
Psych0matt Posted November 2, 2006 Report Posted November 2, 2006 Aweb makes a rear stb, it does not fit on a vert, however Quote
kuntzie Posted November 2, 2006 Report Posted November 2, 2006 quick guestion relating this... does awebb's R STB not work because when the top goes up and down?? or is it something else ? Quote
Guest TurboSedan Posted November 2, 2006 Report Posted November 2, 2006 No. No rear STB on a 'vert. i don't think there was a factory rear STB on any W-body was there? Quote
Psych0matt Posted November 2, 2006 Report Posted November 2, 2006 quick guestion relating this... does awebb's R STB not work because when the top goes up and down?? or is it something else ? I was going to get one, but from what ive heard (not experienced) is that the window folds down right where it would go, so unless you somehow made one that drops a bit, you'll shatter your back window. Quote
Crazy K Posted November 2, 2006 Report Posted November 2, 2006 quick guestion relating this... does awebb's R STB not work because when the top goes up and down?? or is it something else ? I was going to get one, but from what ive heard (not experienced) is that the window folds down right where it would go, so unless you somehow made one that drops a bit, you'll shatter your back window. that is correct. interestingly enough, the hoop is structural, although not really(legally) a rollbar. it helps stiffen the body. Quote
