General tuneup at 71,500 miles
So i'll be changing the oil soon on my 3.1, and I figure I want to change the spark plugs, as i dont really remember when the last time it was done.
I want to make this car run really well. It runs pretty well right now, but occasionally it will have a kindof rough idle (this may be motor mounts, they were replaced about 6 years ago) I'm thinking i'll clean out the idle air sensor behind the butterfly. Should the fuel filter be changed any time soon?
Any other suggestions to general maintenance?
plugs, wires, air filter (if needed), fuel filter, coolant flush (if yours looks dirty), transmission fluid and filter (depending on when it was last done), check out the shape of the serpentine belt.
basic tune up
1. new plugs
2. new wires
3. new pcv valve
4. fuel filter
thats a basic tune up for the 3.1 mpfi hope it helps u
thanks, you guys are awesome!
as for the air filter, i'll get around to rigging up a fender intake one, maybe this winter, if school ever gets less hard.
EDIT:
Just thought of something. Are there any sensors i should replace, like the O2 sensor, or others. When do they usuall go bad?
Heres what I did..
-AC Delco Plat. Plugs
-AC Delco wires
-Fram fuel filter
-Fram PCV
-Seafoam
-Clean TB
-Dropped Trans Pan (new filter / new gasket)
-Changed Oil
Heres what I did..
-AC Delco wires
-Fram fuel filter
-Fram PCV
-Seafoam
-Clean TB
-Changed Oil
Fram FTL.
You should do your O2's also.
fram fuel filter is fine, and PCV WHO CARES I can steal them from work!
o2 are SO god damn expensive@
$40? Stay away from Bosch O2's.
I stay away from anything Fram.
its a good thing mine seems to be ok, cuz it's apparently crossthreaded. One of these days I'll have to deal with that
I would also clean the MAF sensor. only use MAF cleaner though(CRC brand MAF cleaner is like $5)
dont use tb or brake cleaner, they will ruin the sensor.
I've had my bosch 02 Sensor installed for almost 2 yrs and no problems
Well Bosch, IMO has always sucked. Ask Brian P.
Also, the majority of there other products suck.
Correction: The majority of Bosch products for W-bodies suck except for their wiper blades. :lol:
Finally! Another Philadelphia area person! Why the hell is your car called the bruise? Have the conditions here in the Philly area been that bad to your car (bad drivers, bad roads etc.)? :lol:
:werd: on teh Bosch crap. Although the wiper blades do rock. ive had mine for like a year and a half and they still work great
haha its called the bruise because its black and blue, haha.
