ac delete
97CuttySupSL
so im thinkin about takin out my ac..to much weight and jus dont use it..did the 1st gen ws come stock with ac or was it a upgrade?? beacuse if i can find a w with a you delete id be in luck..or i would jus go with a smaller belt..
so my ? is did any 1st gen ws come without ac??
IMHO unless you plan on an engine swap somewhere down the road the weight of the AC still wont change the fact that you have a 16-17 sec car.
Leave it in because when you go to sell it people want AC
Its only about 20-30lbs total, and when your not using your A/C, theres such little drag that your engine doesnt notice it. Its not worth it to take it out.
Guest TurboSedan
too much weight? the entire underhood AC system weighs 30lbs MAX. AFAIK all W-bodies had AC. although maybe some of them sold up in Canada didn't?
when i deleted my AC i mainly did it to make room for a FMIC later on but also to clean up the engine bay - it's now easier to replace/reach the starter, oil pressure switch, coilpacks etc. besides i hardly ever used AC anyway and it was out of refridgerant.
i used the GM non-AC pulley ordered for an '88 Corsica with a 2.8L and no AC and then went and bought a serpentine belt from Checker for the same Corsica application. works great. since you have a 3100 things might be different for you.
or you can just bypass the AC pulley :dunno: and call it a day!
the old 3.1 motors, in 88 the pontiac grand prixs had optional ac. after 1989 all w's came with ac stock. so you would have to find an ac delete pully.
Guest TurboSedan
they do sell those u know.
IIRC it cost me about $23 from my local GM dealership:
http://www.turbosedan.com/cutlass/engine/DSC01668.JPG
comes with the bolt unlike the ones you can buy at Checker/NAPA etc.
http://www.turbosedan.com/cutlass/engine/DSC01669.JPG
http://www.turbosedan.com/cutlass/engine/DSC01670.JPG
mounting hole location (3.1 MPFI of course):
http://www.turbosedan.com/cutlass/engine/DSC01678.JPG
installed:
http://www.turbosedan.com/cutlass/engine/DSC01679.JPG
and yeah all of this stuff doesn't weigh very much:
http://www.turbosedan.com/cutlass/engine/DSC01454.JPG
that pic doesn't include the compressor but that's still maybe only 10lbs.
i meant a kit that actually sits in place of the ac compressor so you can use the stock belt size. both do the same thing.
its not so much the weight....but i just dont use it..and i dont plan on selling my car..plus i dont think it even works...so ya..but thanks guy nfor the info
  • 2 weeks later...
I think you still use your stock belt with that pulley. Someone on here before left the part number from like Autozone. If you do a search on here you might come across it. I never use my AC. ACs are for crybabies. :burnout:
