supreme_style21 Posted May 25, 2003 Report Posted May 25, 2003 How do I PROPERLY disable the power to my power antenna without losing reception, of course. Mine goes up fine, but once it is time to go down, look out. Goes down 'bout half way, stops, then makes this LOUD embarassing grinding noise.. the kind of noise that makes people stop and look... So I'm going to put the thing in the UP position and cut off it's power. Or maybe someone knows how to fix it.. cheaply. Quote
91GranSport Posted May 25, 2003 Report Posted May 25, 2003 There's an electrical connector going to the power antenna. Unplug that electrical connector and then you're done. Quite simple and it should take about five minutes! Quote
89BuickRegalGS Posted May 26, 2003 Report Posted May 26, 2003 i would buy a replacement kit, its like $11.00 for a replacement that is not motorised and just sticks up off teh back of the car. I bought one for mine, messed up the little rubber piece that fits against the rear fender, and had to useone supplied with the kit for another model of car, and it ended up giving the antenna a nice raked back look that I liked. Quote
Justin Posted May 26, 2003 Report Posted May 26, 2003 Sounds to me like the plastic gear on your mast is stripped, you could either unplug it, or just replace the mast. Quote
PJB Posted May 26, 2003 Report Posted May 26, 2003 I dont know what one costs from a junkyard, but theyre simple to replace. I just changed the one on my friend's '97 CS with one from a parts car. 10 minutes and the 'new' one was installed and working in his car (including removing it from the parts car). Quote
jesse Posted May 28, 2003 Report Posted May 28, 2003 It is bent ever so slightly, and the motor is designed to slip so that it does not break it off if it is iced or bent, or break the fuse. Will be impossible to straighten it out, is caused by the years of driving, it will bend toward the rear. Unplug the power while the radio is on and all will be fine, remember to plug it back in and lower it before going through a car wash though. Quote
