R Dubya Posted November 8, 2006 Report Posted November 8, 2006 well if it ran fine before you tore it apart, you should begin another teardown to find out what happened. Something isn't right in there, sounds to me like its losing vacuum. Quote
slick Posted November 13, 2006 Report Posted November 13, 2006 Coils are aftermarket? What brand? Quote
KCFITZ78 Posted November 13, 2006 Author Report Posted November 13, 2006 I think coils are wellman? I would have to check that. Quote
KCFITZ78 Posted December 4, 2006 Author Report Posted December 4, 2006 I have no idea and I give up on this engine. I am junking the car. I don't have a place to store and work on the car so there is no reason for me to keep it. I have been all over this and only thing left to do is pull the engine and do a rebuild because something must be broke. Will never know!!! Checklist -no visable leaks, good -sprayed ether and no vaccum leaks, good -vaccum tested and was fine, 17", good -pulled valve covers and checked bent rods, good -blocked off egr in case egr was stuck open, good -dissconnected cat in case cat was pluged, good -compression tested 150 to 160 psi throughout all cylinders, good -checked coils, good -checked wires for spark, good -rechecked firing order, good -black plugs, put in new plugs Car will idle, but rough. Also there is a knock in the engine but it is not consitant. Was able to drive bout 250 yards, but was down a cylinder or two. Anyone want to make any offers? Will make a post by end of week w/ pics, car options, replaced parts, and any history as long as I had it. Quote
IRONDOG442 Posted December 4, 2006 Report Posted December 4, 2006 I'll give you a large bag of pizza rolls, i'll even cook them for you I live in Toledo. Quote
White93z34 Posted December 4, 2006 Report Posted December 4, 2006 so here is a dumb question, did you replace the spark plugs when you did the headgaskets? as for the running hot, what does the actual gauge say? and are you getting a SES light? Quote
KCFITZ78 Posted December 4, 2006 Author Report Posted December 4, 2006 It does not run hot any more and has never thrown a code. (It took awhile to get the coolant purged). Yes i did. I am on the 3rd set of plugs. I was asked this before So without me having to search through everything you wrote could you please enlighten me of whether or not you changed the spark plugs? Black means rich, which means you had a vac leak or some other catalyst for running rich. It's not gonna throw a code for a misfire because its a '94 (I think, never dealt with one yet). If they were black I would suggest replacement of all 6 if you didn't do it before. Quote
IRONDOG442 Posted December 4, 2006 Report Posted December 4, 2006 I had the exact same problem happen to me on a 95 supreme coupe search my posts. Quote
Brian P Posted December 4, 2006 Report Posted December 4, 2006 It does not run hot any more and has never thrown a code. (It took awhile to get the coolant purged). Yes i did. I am on the 3rd set of plugs. I was asked this before So without me having to search through everything you wrote could you please enlighten me of whether or not you changed the spark plugs? Black means rich, which means you had a vac leak or some other catalyst for running rich. It's not gonna throw a code for a misfire because its a '94 (I think, never dealt with one yet). If they were black I would suggest replacement of all 6 if you didn't do it before. So you mean to tell me that your overheating was because of purging the coolant? So even after I told you that, and you gave me the attitude, that I was right? THE COOLANT IS CYCLING, WATER PUMP SPINS, AND THERMOSTAT OPENS. ALL WAS REPLACED WITHIN THE LAST 4 MONTHS TOO. I AM MORE WORIED ABOUT THE SOMETIMES HARD START UP, ROUGH IDLE, AND THE FACT ONCE I PUT IT IN GEAR IT WILL STALL. THE FACT THAT ENGINE GETS HOT IS NOT A COOLING PROBLEM, IT GETS HOT BECAUSE IT IS NOT RUNNING AS IT SHOULD. Quote
KCFITZ78 Posted December 4, 2006 Author Report Posted December 4, 2006 Possible title name? Having trouble finding any post for you. I had the exact same problem happen to me on a 95 supreme coupe search my posts. Quote
KCFITZ78 Posted December 4, 2006 Author Report Posted December 4, 2006 It wasn't an attitude. I use all caps at work on blueprint drawings so it was a mistake. (I am human) And as far a i knew the coolant was purged. I left the radiator cap off over night and other opening hoping any air to rise out of the coolant lines. Quote
Crazy K Posted December 4, 2006 Report Posted December 4, 2006 sounds like my cars. all 4 of 'MY' cars. what brand of plugs? boschs foul out immediately in our cars. To ensure no air exists in you eninge coolant passages. the best(easiest) place to see the highest point of coolant on the 3100 motor is where the engine temperature sensor is located, angling up towards the front right next to the thermostat. Pull that out and make sure you have coolant visible through the port. If in doubt about the reliablility or age of the temp sensor, replace it. I had one 3.1 car that would not start after a LIM change. I think I left the kleenexs I used to block the ports in the engine. smoked like $#!+ for a bit once it started. They were sucked into the enigine and had to be burned out Quote
digitaloutsider Posted December 4, 2006 Report Posted December 4, 2006 Did you replace the wires? Try a known ICM/coilpack set? Quote
KCFITZ78 Posted December 4, 2006 Author Report Posted December 4, 2006 For plugs, 2 sets of copper ac delcos burnt up and now I have regular copper champions in. Also as a side note, I did replace the temp sensor. I broke the wires off while working on it. When i had the overheating problem way back in the summer I bought one when I put a new radiator and water pump in. I never replaced it because i lost it. Good thing I found it even if the car runs like crap. Quote
Crazy K Posted December 4, 2006 Report Posted December 4, 2006 a way to find intake leaks, if that might be the current probelm is to spray...uhh starting fluid? ... around teh intake gaskets while your engine is running. If you engine reacts, it shows you do have a leak. sort of the same with a busted vaccum line. I'm itching to say you have a vac leak somewhere. Quote
KCFITZ78 Posted December 4, 2006 Author Report Posted December 4, 2006 Why replace wires when the deliver spark, and why replace coils when they produce spark? Wires and coils were replaced 2 1/2 yrs ago. Maybe my multi meter needs replaced because it could be giving fasle values. <-----now thats attitude Quote
KCFITZ78 Posted December 4, 2006 Author Report Posted December 4, 2006 Hope this helps so i don't have to answer the same questions that i have asked myself. Sorry i know this is a long read but i think everything has been done that can be without pulling the engine and doing a rebuild. I have no idea and I give up on this engine. I am junking the car. I don't have a place to store and work on the car so there is no reason for me to keep it. I have been all over this and only thing left to do is pull the engine and do a rebuild because something must be broke. Will never know!!! Checklist -no visable leaks, good -sprayed ether and no vaccum leaks, good -vaccum tested and was fine, 17", good -pulled valve covers and checked bent rods, good -blocked off egr in case egr was stuck open, good -dissconnected cat in case cat was pluged, good -compression tested 150 to 160 psi throughout all cylinders, good -checked coils, good -checked wires for spark, good -rechecked firing order, good -black plugs, put in new plugs Car will idle, but rough. Also there is a knock in the engine but it is not consitant. Was able to drive bout 250 yards, but was down a cylinder or two. Anyone want to make any offers? Will make a post by end of week w/ pics, car options, replaced parts, and any history as long as I had it. Quote
KCFITZ78 Posted December 4, 2006 Author Report Posted December 4, 2006 This is what I have left to try to get it running: -check fuel injectors? (use multimeter) -check fuel injector fuse? -idle relearn? (if mine can do that) -clean and check IAC? -check any other fuses? -look for pinched or bad wires? -use seafoam and watch it die and never restart…..hahahahahahahaha :lol: :lol: :lol: :lol: :lol: :evil: :evil: ..............If i do i'll be sure to get video so you can see the engine blow, that would be good for it to blow so i know its past the point of no return Quote
IRONDOG442 Posted December 4, 2006 Report Posted December 4, 2006 Possible title name? Having trouble finding any post for you. I had the exact same problem happen to me on a 95 supreme coupe search my posts. FOUND IT !!!! http://www.w-body.com/forum/index.php/topic,45536.msg544741.html#msg544741 Quote
KCFITZ78 Posted December 4, 2006 Author Report Posted December 4, 2006 So your mechanic said bad fuel injector or bad pigtail. Did you ever dig into it? I have't checked that becuase my plugs where black so I felt I was getting fuel. I have it on the check list to check injectors but will also check the pigtail to the injectors too. Thanks, this wil be the last thing I check and then its gone if that doesn't work! Quote
IRONDOG442 Posted December 4, 2006 Report Posted December 4, 2006 Yeah my guess is its a fuel problem, it could also be a crank sensor did you short out the wires that go by the a/c compressor??? Quote
KCFITZ78 Posted December 4, 2006 Author Report Posted December 4, 2006 Maybe. I had to remove the compresser to get the bracket off, but the battery was disconnect. Well it wasn't disconnect all the time. I have no trunk lock so i have to have power to trip the solenoid to open the trunk. Quote
Canada Posted December 5, 2006 Report Posted December 5, 2006 Not to be a dick, but this is why some people shouldn't work on cars. That said, what is the cars current running condition? Quote
THe_DeTAiL3R Posted December 5, 2006 Report Posted December 5, 2006 I was surprised my car started right up after I did the LIM for the first time last year. I mean it's a pretty big job if you've never done it before. I did however forget to tighten the TB so it was bouncing off the rev limiter due to crazy vacuum leak, but I quickly got it figured out. Quote
GP1138 Posted December 5, 2006 Report Posted December 5, 2006 I did however forget to tighten the TB so it was bouncing off the rev limiter due to crazy vacuum leak, but I quickly got it figured out. I'll bet that first start-up scared the piss out of you! Quote
