slick Posted October 25, 2006 Report Posted October 25, 2006 I can't exactly think of the correct name for this right now, but when someone does post it, i'll change the title of the thread. Anyways, some people have posted up pictures of there trunk, and the inside of there trunk lid, they have a custom liner that(I'm assuming is made out of MDF) but usually has like GTP, or some emblem sticking out of it. I know the jist of how to make it, but how do they stay up against the trunk lid? Every one that I have seen never has any visible screws, bolts, or clips. Thanks, Chris Quote
Psych0matt Posted October 25, 2006 Report Posted October 25, 2006 good thread, ive been wondering the same thing, and since ill have some time this winter to do things that was one i wanted to do Quote
slick Posted October 25, 2006 Author Report Posted October 25, 2006 Well... I know how to make it, or atleast a few ways of making it, but not sure how everyone mounts theres. Quote
digitaloutsider Posted October 25, 2006 Report Posted October 25, 2006 Wood blocks they shove up into the little cutouts on the trunk lid. The panel is then screwed to that. Quote
slick Posted October 25, 2006 Author Report Posted October 25, 2006 Wood blocks they shove up into the little cutouts on the trunk lid. The panel is then screwed to that. So are the screws visible, or do they cover the liner once it is on the trunk lid? Quote
terryk2003 Posted October 25, 2006 Report Posted October 25, 2006 i believe you will find everything you need to know HERE: http://www.resyuh.com/ Quote
slick Posted October 25, 2006 Author Report Posted October 25, 2006 So.... looks like they use some 3m heavy duty double sided tape then, right? It also appears there's are just a pressed formed carpet or foam covered carpet, right? If so, the 3m tape won't hold up the MDF very well Quote
sclary18 Posted October 25, 2006 Report Posted October 25, 2006 im going to be making mine soon, heres how im doin it... im going to take some particle board shit, and screw that into the trunk lid, then... im takin wood pieces and makin it say "Oldsmobile" or "Cutlass" or something.. you take those wood pieces and screw them into the particle board before you attach it to the trunk.. then you buy a can of 3m hi-strength spray glue from lowes or home depot, and spray the wood and the carpet or whatever you decide to use (i'm using red suede). let it sit for a minute, and then press the carpet onto the particle board and move out the wrinkles untill your satisfied.. once your done pressing it on the particle board, you can immediately attach it to the trunk lid. THE END.. let me know if you dont understand or have any questions.. Quote
slick Posted October 25, 2006 Author Report Posted October 25, 2006 Wait, so how are you going to idependantly going to attach it to the trunk lid if you already have it screwed to the trunk lid and your covering your screw holes with the suede. I know how to make it, i'm just more concerned about how it will attach, and how well it will stay attached to the trunk lid. Quote
terryk2003 Posted October 25, 2006 Report Posted October 25, 2006 So.... looks like they use some 3m heavy duty double sided tape then, right? It also appears there's are just a pressed formed carpet or foam covered carpet, right? If so, the 3m tape won't hold up the MDF very well its NOT double sided tape...its more like a velcro type press and lock... http://www.313motorsports.com/resyuh/index.php?option=com_content&task=view&id=27&Itemid=53 Quote
slick Posted October 25, 2006 Author Report Posted October 25, 2006 So.... looks like they use some 3m heavy duty double sided tape then, right? It also appears there's are just a pressed formed carpet or foam covered carpet, right? If so, the 3m tape won't hold up the MDF very well its NOT double sided tape...its more like a velcro type press and lock... http://www.313motorsports.com/resyuh/index.php?option=com_content&task=view&id=27&Itemid=53 I tried opening that page when I was on the website, but it wouldn't work for me. I wonder how much that stuff costs. Quote
sclary18 Posted October 25, 2006 Report Posted October 25, 2006 nooooooo... what you do is first attach the wood pieces to the particle board, acutally i'll probably just hot glue the wood pieces onto the particle board.. and then you take the hole entire particle board and pieces attached and attach it to the trunk lid, then carpet it.. Quote
slick Posted October 25, 2006 Author Report Posted October 25, 2006 So your carpeting it once it's on the trunk lid then? Eh.... I'll find another way of doing it. I'd rather carpet it off of the trunk lid, that way i can be sure to get it done right, and not have to worry about the damn trunk lid falling while I'm working on it. Quote
sclary18 Posted October 25, 2006 Report Posted October 25, 2006 yeah, another way of doin it is to carpet it while its off the car, and then you screw it on and take a small piece of carpet and put it over the screws.. kinda like a cap... Quote
slick Posted October 25, 2006 Author Report Posted October 25, 2006 yeah, another way of doin it is to carpet it while its off the car, and then you screw it on and take a small piece of carpet and put it over the screws.. kinda like a cap... Yeah, I've thought of that also. I have a few other idea's floating around in my head about how to hold it on, but only time will tell because it will all depend on how heavy it is. Quote
Psych0matt Posted October 25, 2006 Report Posted October 25, 2006 hmmm, i wonder if i could make one with the outline of the cutlass from the decal... Quote
pwmin Posted October 25, 2006 Report Posted October 25, 2006 http://www.clubgp.com/newforum/tm.asp?m=3219966&appid=&p=&mpage=1&key=trunk+lid&language=single&tmode=&smode=&s=#3242390www.grandmatdesign.com http://www.clubgp.com/newforum/tm.asp?m=3306826&appid=&p=&mpage=1&key=&language=single&tmode=&smode=&s=#3306826 Quote
19Cutlass94 Posted October 25, 2006 Report Posted October 25, 2006 Ive been wanting to make one for years. I just have to find a place that makes custom upholstry around me then Ill be done. Quote
slick Posted October 26, 2006 Author Report Posted October 26, 2006 http://www.clubgp.com/newforum/tm.asp?m=3219966&appid=&p=&mpage=1&key=trunk+lid&language=single&tmode=&smode=&s=#3242390www.grandmatdesign.com http://www.clubgp.com/newforum/tm.asp?m=3306826&appid=&p=&mpage=1&key=&language=single&tmode=&smode=&s=#3306826 I don't have a GP, so that doesn't help me much really. All that I seen was to order some. Quote
pwmin Posted October 26, 2006 Report Posted October 26, 2006 well, i dont care if it helps you or not! idk, i made one out of cardboard and carpet once and it didnt last long at all (obviously) i used friction fittings to hold it to the trunk (had to drill holes) and it didnt work too well. maybe the gp ones would fit your trunk lid and you can get them to do any wording you want, but its gonna cost. you can email the guy from the website and see how they fasten theirs. Quote
97CuttySupSL Posted October 26, 2006 Report Posted October 26, 2006 im sure you could find some good velcro at like a crafts store or something..i might attempt this for the cutlass Quote
19Cutlass94 Posted October 26, 2006 Report Posted October 26, 2006 Velco wont hold it. Especially if you have a sub that you use. I mean actually use. Quote
J Posted October 31, 2006 Report Posted October 31, 2006 local audio shops will make you one for pretty cheap if you put thier name on it. Then u go home and cut out GP or a bowtie and "re-do" it and have one custom made for the price they charge. The local place around my buddy does it for $50 bucks Quote
19Cutlass94 Posted October 31, 2006 Report Posted October 31, 2006 pshh, I wish it was that cheap here. Everyplace I went to around here quoted me $200-$400. So therefore starting this week, Im going to be making my own. Quote
slick Posted October 31, 2006 Author Report Posted October 31, 2006 I will probably make mine out of 1/4" MDF. My plan is to cut the MDF to the desired shape that I want, then using the push in style clips that hold in the trunk liner(you know those little pop in plastic clips), then drill the holes in the MDF where the push clips need to go through(gotta be sure to pick up some long ones). Then, pull the MDF back down, put my desired design onto it, carpet it, make the holes for the push clips through the carpet, and pop it into place on the trunk lid. BTW, we have the heavy duty 3m velcro tape at work, so I can use that on the edges to control rattling! Quote
