taillight swap?
I have been browsing ebay and I have toyed with the idea of a Lumina taillight/center section swap. What do you think? Yay or nay?
it would be different, but i say keep yours. now if you had a lumina and wanted to swap for montes id say go for it. get some pics, if i remember correctly i do like the lumina lights, but not the center section
ah true. I was thinking of just the lights, but it appears the inner lights are part of the center section?
nevermind. I found both tails for $68 inc shipping. I will buy them thursday night (hopefully).
(oh shit I gave away some of my tease. fuck)
wow, thats kinda a lot. hit up some junkyards, should be able to get those real cheap
true, but the only decent JY in my area is the chevy dealerships parts lot. :(
They are usually expensive at junkyards too. My sis busted a tailliight on her 95 Monte about a year ago. I called 4? junkyards within 30min of home and cheapest I found was $40.
:werd: junkyards are almost always expensive on the shit you would figure you could pick up for cheap. thats why i dont bother looking... i see the odd monte carlo hit the yard by work but i dont even check, they are crazy priced there
I honestly wouldn't put Lumina tails on a Monte or vise versa unless you get the appropriate center section. You can swap the Monte tails/trunk panel to a Lumina, but not vise versa (atleast not without welding/paint work involved) The tail lights will swap without a problem, but you run into problems with the center section. Luminas have 2 fewer bolts on the center panel than the Monte does. Which means if you were to do the swap, you'd have two plainly visible holes.
As far as just doing just the tail light swap, nay as well. Lumina tails are a little bit different in shape than the Monte tails, and unless you have the center section they will not line up properly. Word of advice, don't do it. The gap will drive you nuts if you care anything about them. Here is a picture of a Monte panel in comparison with a Lumina panel (Tail lights are harder to see the difference)
I never really like the standard lumina rear end...I think that is part of the reason why I like the LTZs so much more
yeah, i dont get why people on MM put lumina tails on their monte.....when the monte tails look alot better
yea. I have decided not too since I have seen one in person with it, and it looks bad. More money for other mods.
:thumb: Much Better Choice.
