Intermittent Heater
I have a 92 Z34 and the problem I have is when the car is running and the heater is on full, there is no heat coming out of any of the vents. Its just cool air no matter what setting I have it on. Once I put the car in gear and drive around...the heat comes back on?? but if I stop at a light or stop sign, it will turn back to cool air?? So there's heat when the vehicle is in motion but no heat when the vehicle is at a stand still. the coolant level is always good and I had the water pump replaced a few months ago.
Any suggestions?
What is the temperature guage reading when you lose the heat? I would try and bleed any air out of the cooling system and go from there.
