Bri-Guy-GA Posted October 23, 2006 Report Posted October 23, 2006 What would cause the directionals to blink real slow? I am talking once every 10 seconds or so. Seems the bulbs are ok. where is the flasher hidden? Quote
97loudcut Posted October 23, 2006 Report Posted October 23, 2006 inside the fuse panel (driver side) Quote
Bri-Guy-GA Posted October 23, 2006 Author Report Posted October 23, 2006 My fuse panel is on the passenger side where the door meets the dash. Still in there or on drivers side? Quote
digitaloutsider Posted October 23, 2006 Report Posted October 23, 2006 Unless they moved it around on the 94-up's, the turn signal flasher is on the driver's side above the accelerator. The 4-way warning flasher one is mounted to the under-dash passenger side fuse panel. Quote
Bri-Guy-GA Posted October 23, 2006 Author Report Posted October 23, 2006 Unless they moved it around on the 94-up's, the turn signal flasher is on the driver's side above the accelerator. The 4-way warning flasher one is mounted to the under-dash passenger side fuse panel. I will look for it under the dash on the drivers side. Think that is why they blink so slow? Quote
slick Posted October 23, 2006 Report Posted October 23, 2006 Most likely, yes. If I were you, I'd spend the extra cash and pick up an electronic flasher while your at it. It doesn't slow down like the normal flashers when it gets cold out. Quote
GOT2B GM Posted October 23, 2006 Report Posted October 23, 2006 Most likely, yes. If I were you, I'd spend the extra cash and pick up an electronic flasher while your at it. It doesn't slow down like the normal flashers when it gets cold out. w3rd Thats what fixed mine. Quote
DiscoStudd Posted October 23, 2006 Report Posted October 23, 2006 Unless they moved it around on the 94-up's, the turn signal flasher is on the driver's side above the accelerator. The 4-way warning flasher one is mounted to the under-dash passenger side fuse panel. The turn signal flasher is still in the same spot on the 94+, but the hazzard flasher is clipped to the dash support underneath the headlight switch... Quote
