turbo90gp Posted October 19, 2006 Report Posted October 19, 2006 So went to work on the TGP today, and before hand I had to cut the head off of the Passenger Rear Subframe bolt to remove the subframe. Done, no problems. Well today I went to go see if I could remove the rest of the bolt. Sure enough, SNAP, and now I have half the bolt in my vicegrips, and the other half is up inside the unibody buy the pass. floorboard. Any suggestions? The thing that pisses me off is that I am pretty sure the tranny shop who had to put in a reverse shaft rail guide cross threaded it because it came out no problem after 14 years, and about 2 years later, its all seized up. It is the only one Quote
Crazy K Posted October 19, 2006 Report Posted October 19, 2006 you can replace the nut and everything.......... the FSM basically tells you to air chisel it out, and replace the nut.... there is a plastiuc plug facing forward on the ares in front og the cage, that provides limited access. I broke a rear subframe bolt on my 92 lumina, I simply cut a 3 sided hole behind the carpet for access. replaced the nut, and once the new nut was threaded and locked, I bent the flap closed and sealed it with rtv, and a layer of plastic right on top to seal it forever. Quote
jdcutty Posted October 21, 2006 Report Posted October 21, 2006 sound like a pain in the ass. Good luck man. Quote
