Dark Ride Posted October 18, 2006 Report Posted October 18, 2006 First: Will A Transmission Off a 95 GP with a 3100 fit a 95 Chevy Lumina with a 3100. I was Positive It would, but my dad talked to the guy at the junkyard and he said the Luminas and Monte carlos were different. Second: Will A motor and tranny off a 94 cutlass supreme work in a 95 GP? Looking at swapping the entire cradle and everything since its way easier. I remember something about OBD 1 vs. OBD 1.5. Does that matter in this case? Thanks, Mitch Quote
Robby1870 Posted October 18, 2006 Report Posted October 18, 2006 1. Yes, it's the same transmission, hell, they are the same car. 2. Yes, both 94 & 95 are OBD 1.5 so it should be a direct swap. Quote
CSI_MuNkY Posted October 18, 2006 Report Posted October 18, 2006 To answer your first question... The transmissions are the same, both would be the 4T60E And should be a direct swap As for your second question... The 95 GP will likely be OBD 1.5, the 94 Engine will be OBD 1....How much difference there is between the 2 I'm not 100% sure, maybe someone else can chime in with that... Jamie Quote
CSI_MuNkY Posted October 18, 2006 Report Posted October 18, 2006 Yes, both 94 & 95 are OBD 1.5 so it should be a direct swap. I thought OBD 1.5 was a 1995 thing... my mistake Jamie Quote
GP1138 Posted October 18, 2006 Report Posted October 18, 2006 As for your second question... The 95 GP will likely be OBD 1.5, the 94 Engine will be OBD 1....How much difference there is between the 2 I'm not 100% sure, maybe someone else can chime in with that... Jamie They should both be OBD 1.5. The only car I believe that got OBD 1 in '94 was the last Luminas before they facelifted them... but I could be wrong. Quote
Robby1870 Posted October 18, 2006 Report Posted October 18, 2006 As for your second question... The 95 GP will likely be OBD 1.5, the 94 Engine will be OBD 1....How much difference there is between the 2 I'm not 100% sure, maybe someone else can chime in with that... Jamie They should both be OBD 1.5. The only car I believe that got OBD 1 in '94 was the last Luminas before they facelifted them... but I could be wrong. Yeah, the 94 Lumina was the only W that year to get the 3.1L and it was OBD1. Quote
CSI_MuNkY Posted October 18, 2006 Report Posted October 18, 2006 As for your second question... The 95 GP will likely be OBD 1.5, the 94 Engine will be OBD 1....How much difference there is between the 2 I'm not 100% sure, maybe someone else can chime in with that... Jamie They should both be OBD 1.5. The only car I believe that got OBD 1 in '94 was the last Luminas before they facelifted them... but I could be wrong. Now that I think about it, I think your right... Based on the fact that Ben over on 60* has chipped the 91-93 engine but NOT the 94-95 engine... Makes sense that the reasoning for this is OBD 1.5... Jamie Quote
Dark Ride Posted October 19, 2006 Author Report Posted October 19, 2006 Cool, Thats What I Thought Thanks Quote
