Q-Ball Posted October 17, 2006 Report Posted October 17, 2006 I just bought this. I asked about Seafoam and got a weird look. So I asked about something to clean out the engine and I got this kit. Its called TKO-Total Kombustion Overhaul. Any good? Heres a pic and description. Professional set designed to complex cleaning the whole fuel system. Knock out combustion chamber deposits, intake valves and fuel injector deposits. Restore engine performance. Reduces exhaust emissions. Stops engine knock and run on. Restores smooth idling. Contains one of each: Combustion Chamber and Intake Valve Cleaner Fuel Injector Cleaner Engine Antacid Air Intake System Cleaner Quote
THe_DeTAiL3R Posted October 17, 2006 Report Posted October 17, 2006 How much did that cost you? Sounds like a bunch of fancy names for stuff that you might be able to buy for cheaper.. Combustion Chamber and Intake Valve Cleaner - Seafoam/AC Delco Kleens Fuel Injector Cleaner (million different brands of those, all the same stuff) Engine Antacid <- wtf? Air Intake System Cleaner - TB cleaner Quote
Q-Ball Posted October 17, 2006 Author Report Posted October 17, 2006 How much did that cost you? Sounds like a bunch of fancy names for stuff that you might be able to buy for cheaper.. Combustion Chamber and Intake Valve Cleaner - Seafoam/AC Delco Kleens Fuel Injector Cleaner (million different brands of those, all the same stuff) Engine Antacid <- wtf? Air Intake System Cleaner - TB cleaner I got it for 34.25 with tax. Quote
AWeb80 Posted October 18, 2006 Report Posted October 18, 2006 $6 can of seafoam is just as good..... Quote
Q-Ball Posted October 18, 2006 Author Report Posted October 18, 2006 Engine Antacid - Motor Oil Addictive (This is whats on the back) Effective neutralizing oil addictive. Combats acid formation in the oil to prevent corrosion and wear on the camshafts, valve lifters and internal engine parts. Provids all weahter protection against dry starts. Helps prevent formation of sludge, varnish and gum by keeping the dirty particles in suspension which are removed by the oil filter during circulation. Improves fuel efficiancy by reducing friction. Directions: Compatible with all SAE motor oils, whether petroleum based or synthetic. Pour contents into crankcase before using TKO Combustion Chamber and Intake Vavle Cleaner. Quote
GutlessSupreme Posted October 18, 2006 Report Posted October 18, 2006 I got it for 34.25 with tax. I don't see any lube included in that kit. Quote
97loudcut Posted October 18, 2006 Report Posted October 18, 2006 I got it for 34.25 with tax. I don't see any lube included in that kit. yeah no shit Quote
THe_DeTAiL3R Posted October 18, 2006 Report Posted October 18, 2006 Seafoam or equivilant= $6 F.I. cleaner like $3 oil additive- unnessesary - like under $10 for basic stuff TB cleaner- like $5 you could have spent half as much for the stuff you needed. Really just the Seafoam (or AC Delco Kleens available at GM dealers) and TB cleaner to spray in the intake would be plenty. Putting stuff in the oil is a waste of money. Quote
digitaloutsider Posted October 18, 2006 Report Posted October 18, 2006 AutoZone here has Seafoam for $3.99 a bottle. Quote
Q-Ball Posted October 18, 2006 Author Report Posted October 18, 2006 Seafoam or equivilant= $6 F.I. cleaner like $3 oil additive- unnessesary - like under $10 for basic stuff TB cleaner- like $5 you could have spent half as much for the stuff you needed. Really just the Seafoam (or AC Delco Kleens available at GM dealers) and TB cleaner to spray in the intake would be plenty. Putting stuff in the oil is a waste of money. Well I can return it, thats not a problem. Now, I have to find all that crap at canadian tire tomorrow. Quote
rockfangd Posted October 18, 2006 Report Posted October 18, 2006 so not worth it you just got ripped off, the best oil addative is marvel or lucas, any fuel inj cleaner works all the same, and use seafoam Quote
Q-Ball Posted October 18, 2006 Author Report Posted October 18, 2006 The K means it's better It actually means Kombustion, but I guess you forgot to read the first post. Quote
AWeb80 Posted October 18, 2006 Report Posted October 18, 2006 The K means it's better It actually means Kombustion, but I guess you forgot to read the first post. It is sposed 2 b spelled w/ a C.....LOL Quote
Brian P Posted October 18, 2006 Report Posted October 18, 2006 yeah no shit, owned! Maybe it's supposed to only be used on Mercedes Kompressors.. Quote
THe_DeTAiL3R Posted October 18, 2006 Report Posted October 18, 2006 yeah no shit, owned! Maybe it's supposed to only be used on Mercedes Kompressors.. LMAO Quote
MonteCarloChick Posted October 18, 2006 Report Posted October 18, 2006 The K means it's better It actually means Kombustion, but I guess you forgot to read the first post. Well in that case, it should be spelled k0mbuztshuN Quote
AWeb80 Posted October 18, 2006 Report Posted October 18, 2006 The K means it's better It actually means Kombustion, but I guess you forgot to read the first post. Well in that case, it should be spelled k0mbuztshuN Nichole making a funny.....FTW Quote
MonteCarloChick Posted October 18, 2006 Report Posted October 18, 2006 You're lucky you have nice wheels. Quote
AWeb80 Posted October 19, 2006 Report Posted October 19, 2006 You're lucky you have nice wheels. you too... Quote
