Bri-Guy-GA Posted October 15, 2006 Report Posted October 15, 2006 I saw an information center for a 95 GP on ebay. How difficult would it be to add it to my 95 GP? Where does it mount? Is it worth the effort? Quote
Crazy K Posted October 15, 2006 Report Posted October 15, 2006 If you can find one... it must be from a 95 or 94 only, you can install it, and it should have a factory harness fro it hidden behind where it goes, in the top left cubby of the dash. you may see the harness (along with other optional accessory harnesses) through the access panel on the left side of the dash. Quote
Bri-Guy-GA Posted October 15, 2006 Author Report Posted October 15, 2006 I take it you mean that cubby over the light switches. How do you get that thing out? Quote
GP1138 Posted October 15, 2006 Report Posted October 15, 2006 You yank this entire piece off: You'll have to pull the radio bezeling off, which (if you have a console) will require you to remove the console top and remove bolts from behind the radio bezeling. It's not all that hard, there's one 7mm screw and you'll have to flex the part by the instrument cluster, but it comes out fairly easily. The cubbys are seperate from the piece I'm talking about, outlined in white above. Quote
Bri-Guy-GA Posted October 16, 2006 Author Report Posted October 16, 2006 The Ebay guy says it was pulled from a 96. Will that fit my 95, including the wiring? I want this to be plug and play as much as possible. Stange shit happens when you start messing with wiring in the dash. Quote
Psych0matt Posted October 16, 2006 Report Posted October 16, 2006 it should fit physically, but the 96 was programmed differently (i think thats how it goes) Quote
Robby1870 Posted October 16, 2006 Report Posted October 16, 2006 yeah, 96 = OB2, 95 = OBD1.5. If you install it, I think the fuel stuff wont work, but the other stuff will. Quote
Bri-Guy-GA Posted October 16, 2006 Author Report Posted October 16, 2006 Well that sucks. Thanks. No point doing all that work for only part of the funcionality. Will wait for one that works then. Quote
