Guest TurboSedan Posted October 14, 2006 Report Posted October 14, 2006 i pulled the dual outlet exhaust out of my TSTE before it got hauled off so i could try swapping it out for the single outlet exhaust that was in my Turbo Cutlass. this is what i started with: i'm still in the middle of installing it so don't laugh nothing is really lined up yet... this is where i'm welding the TSTE dual outlet exhaust to my factory Cutlass exhaust: this is the hanger before the rear subframe. it bolted right up: as you can see the pipe runs under the rear subframe instead of over it like single outlet exhaust cars have. the exhaust looks really close to the lateral arms in this pic, but that's only because the arms are hanging down pretty far since i don't have struts installed at the moment. i don't think 3" pipe will be a problem. this is the hanger right behind the passenger side muffler. the hangers don't exactly match but i can make them work together easy enough closeup: this is the hanger mount behind the drivers side muffler: and this is where the driver's side hanger is supposed to mount - just behind the sway bar mount. i totally forgot to pull this hanger out of my TSTE before it got hauled off i'm going to have to get another hanger at a j/y and either drill or weld the hanger to the frame in order to mount up the drivers side pipe since my frame has no holes there i didn't get pics of the hangers that are on the outer ends of the muffler (just behind the bumper) becuase it's too hard to get a pic of them. they bolt right up no problem though. i'm obviously going to have to cut an exhuast outlet on the drivers side bumper. unfortunately, the BYP skirting i installed is wider than the cutout that the bumper has, so i'm going to have to cut the bumper wider to match the skirting. i'll closely match the cutout on the drivers side obviously. all in all i'd have to say 3" mandrel bent exhaust should fit a 1st GEN W-body no problem. later on i'm planning on complete 3" mandrel bent exhaust (split into TWO 3" pipes for dual outlet of course) with no cat, no resonator, and two Dynomax Ultraflo mufflers. when i upgrade the turbo i'm going to make my own 3" downpipe using an ATPTurbo.com 3" V-band adapter and an ATPturbo.com Modular V-band pipe as well as a SS flex bellow. Quote
blkinternational Posted October 14, 2006 Report Posted October 14, 2006 NICE WORK i cant wait to se the 3 inch pipe.. i swapped out 92 grand prix exaust on my car when i first wanted duals everything lined up pretty good i just had to cut a notch in my bumper Quote
intern8tion9l Posted October 15, 2006 Report Posted October 15, 2006 very informative on the under subframe pipe routing. i'm def gunna have to go this route Quote
19Cutlass94 Posted October 15, 2006 Report Posted October 15, 2006 x2. I wanna get dual exhaust on my car when I have to do the exhaust. Although Ill need to find another bumper Quote
Psych0matt Posted October 15, 2006 Report Posted October 15, 2006 you should prop the other side up and take a pic further back so we/I can get a closer idea how it will look when done Quote
Guest TurboSedan Posted October 15, 2006 Report Posted October 15, 2006 you should prop the other side up and take a pic further back so we/I can get a closer idea how it will look when done ROFL Quote
19Cutlass94 Posted October 15, 2006 Report Posted October 15, 2006 Itll look pretty good when its done! Quote
Psych0matt Posted October 16, 2006 Report Posted October 16, 2006 Itll look pretty good when its done! werd. that will look really good. what's the 5 speed badge from? and spoiler for that matter? Quote
Guest TurboSedan Posted October 16, 2006 Report Posted October 16, 2006 the spoiler is the factory luggage rack thing the 5-speed badge is from a really old Honda CVCC i found in the junkyard. i got the drivers side of the bumper cut tonight and did some cutting on the passenger side. went through a ton of Dremel cutofff discs. it looks pretty rough right now to say the least (big deal, anyone would have to get down on there knees to even see that area). i still need to go through it with a file to get it shaped just right but i'll do that tomarrow. hopefully i can find the drivers side hangers i need at the local junkyard. then all i'll have to do is get it welded up. Quote
97loudcut Posted October 16, 2006 Report Posted October 16, 2006 Looks good. replace those muffs. Quote
GOT2B GM Posted October 16, 2006 Report Posted October 16, 2006 Looks good. replace those muffs. He's eventually upgrading to 3" exhaust. In the meantime the GP exhaust will look nice on there for sure. Quote
White93z34 Posted October 16, 2006 Report Posted October 16, 2006 woah you guys have cool plates. thats gona look good all done, you definately have one of the coolest cars on this board. Quote
Psych0matt Posted October 16, 2006 Report Posted October 16, 2006 the spoiler is the factory luggage rack thing thats what I thought, but from that angle it looks like a really subtle but good looking spoiler. you should take off the middle rack things and leave just the "spoiler" part but paint it body colored Quote
Guest TurboSedan Posted October 16, 2006 Report Posted October 16, 2006 woah you guys have cool plates. thats gona look good all done, you definately have one of the coolest cars on this board. wow thanks for the compliment! i'll be posting some more pics tomarrow. Quote
Guest TurboSedan Posted October 16, 2006 Report Posted October 16, 2006 finished it up today i got lucky and went out to the j/y that my old TSTE was at and snagged all of the exhaust hangers i forgot to get. they gave them to me for free too! so the exhaust is all installed, completely bolt in - no hacking whatsoever (besides the bumper of course). drivers side bumper cutout: passenger side bumper cutout: i know they don't look the best but no one is going to see the cuts anyway. installed! underside: now all i have to do is weld up the pipes. they lined up perfectly. Quote
Psych0matt Posted October 16, 2006 Report Posted October 16, 2006 awesome now wash the freakin car! Quote
terryk2003 Posted October 16, 2006 Report Posted October 16, 2006 damn...that looks really good actually! Quote
Guest TurboSedan Posted October 16, 2006 Report Posted October 16, 2006 awesome now wash the freakin car! buy me some FFP coilovers so i can drive it! Quote
z284pwr Posted October 16, 2006 Report Posted October 16, 2006 Say!!! I recognize that garage, it really is small with a car in there.... On making it look good instead of leaving it hack job Quote
Guest TurboSedan Posted October 16, 2006 Report Posted October 16, 2006 Say!!! I recognize that garage, it really is small with a car in there.... On making it look good instead of leaving it hack job i'd love to find a sapphire blue dual outlet exhaust bumper from a '91 Cutlass Sedan but i don't think that's gonna happen...soo i had to work with what i got. Quote
Psych0matt Posted October 16, 2006 Report Posted October 16, 2006 do you have any pics of the whole car? I dont know if ive ever seen it (i always thought it was a darker blue or is that someone else maybe...) Quote
Psych0matt Posted October 16, 2006 Report Posted October 16, 2006 what was your old sig pic? maybe ive just never seen anything but the front. dang sexy, though Quote
Crazy K Posted October 16, 2006 Report Posted October 16, 2006 i'd love to find a sapphire blue dual outlet exhaust bumper from a '91 Cutlass Sedan but i don't think that's gonna happen...soo i had to work with what i got. I have seen two 90 or 91 cs sedans with duals. one was an international.... (I got a pic of one) is 91 the only year they had duals? Quote
