krtkohbain27 Posted October 14, 2006 Report Posted October 14, 2006 I got the bar today (part# 12456148 from GMPartsdirect.com) and I can't figure out where the 4 washers go that came with the bar. Anyone know? The only thing I can think of where it could go is between the bolt and the strut tower plate where the little ridges on the washer are facing up. Anyone use them when they installed the bar? Should I use them? Quote
PCGUY112887 Posted October 14, 2006 Report Posted October 14, 2006 There is no need to use those washers, only thing you really need if your drillin holes through the strut tower plates is the thing that looks like a U (2 threaded bolts connected at the heads) and 2 nuts (per side of course). Quote
trainman Posted October 14, 2006 Report Posted October 14, 2006 The washers go on the bolts AFTER you put the bolts thru the holes you drilled in the tower, they keep the bolts in place so you can put the STB and nuts on without the bolts falling out of place. They are also known as 'push-nuts' Chris Quote
krtkohbain27 Posted October 14, 2006 Author Report Posted October 14, 2006 Awesome.. Thanks guys Quote
CSI_MuNkY Posted October 14, 2006 Report Posted October 14, 2006 That bar doesn't happen to fit around the LQ1, does it? Jamie Quote
