Justin Posted May 22, 2003 Report Posted May 22, 2003 My 89 CS has the factory amp, with the bass adjust slider under the fog light button. I am hooking up a small amp and 8" sub tube, and was planning to use high level inputs. Now I noticed my rear speakers have 4 wires to each one, which ones do I use? I have a wiring diagram, I know the blue/white and blue/black say sub out, and the other 2 are regular speaker out, do I need to run speaker wires to the back? If that's the case, I'll just run RCA's. I do have an aftermarket deck, I'm just too lazy to run the cables. But if that's what's needed, I guess I'll have to. Also, anyone else that has the premium 4 wire speakers, does your bass slider seem to do anything? Mine sure doesn't. Quote
Pabz Posted May 22, 2003 Report Posted May 22, 2003 Mine doesn't do squat, when hooking up the highlevel inputs i used the yellow and brown wire on one side and the other side i think is dark blue and light blue. Quote
Guest Posted May 23, 2003 Report Posted May 23, 2003 I just bought a 1997 Cutlass Supreme. I have the four wires going to each speaker to. Do I have an extra amp somewhere. If it does where is it? :?: Quote
Guest Posted May 23, 2003 Report Posted May 23, 2003 I just bought a 1997 Cutlass Supreme. I have the four wires going to each speaker to. Do I have an extra amp somewhere. If it does where is it? :?: 1997 Oldsmobile Cutlass Supreme SL Series II Quote
Justin Posted May 23, 2003 Author Report Posted May 23, 2003 Yeah, I would guess you do, as to the location, I know the amp for the 89 is supposed to be under the dash, near the steering shaft. So under that black panel on the drivers side. As for a 97, since they changed the dash, I'd look there first, but it could be anywhere. My 92 Z34 has a bose amp hung between the rear 6X9s, but you would have seen that when you saw your 4 wire speakers. Quote
