kuntzie Posted October 12, 2006 Report Posted October 12, 2006 ok so im hving a serius issue with my transmission.... the uninstall that is... im doing everything the same way i usually do (last tranny install, and numerous tranny pulls from junk yards/ j-bodies anyways... i know how the release bearing works and all but the ***************** transmission wont come apart from the god damn motor, like it twists and everythng, comes out tlike a 1.2" all aound and gets stuck and wont come out anymore not to mention the fucking snow just started to come down quickly. help a broher out with what im doing wrong/ anyway i can break the trans loos from the clutch disc Quote
GOT2B GM Posted October 12, 2006 Report Posted October 12, 2006 shit.... its been awhile since I pulled the 284 out of my parts Z34 so I cant really remember .....sorry. Quote
Crazy K Posted October 12, 2006 Report Posted October 12, 2006 did you remove all parts of the access plate that protect the clutch? is the starter in the way? Quote
kuntzie Posted October 12, 2006 Author Report Posted October 12, 2006 did you remove all parts of the access plate that protect the clutch? is the starter in the way? ya they are all removed, the starter is still in but has never caused me problems before Quote
99RegalGS Posted October 12, 2006 Report Posted October 12, 2006 Try putting a jack under the trans and tilt the engine a bit more. Quote
kuntzie Posted October 12, 2006 Author Report Posted October 12, 2006 Try putting a jack under the trans and tilt the engine a bit more. tried that, tried shiftign the motor, tired shifting the tranny, tried 4 pry bars at one, its just not working Quote
99RegalGS Posted October 12, 2006 Report Posted October 12, 2006 maybe you should reconnect the trans to the engine and pull them out together. W's have lots of space for that. Quote
5speedz34 Posted October 13, 2006 Report Posted October 13, 2006 Did you pull the slave cylinder off/ and or the plastic boot to remove the rod that attaches to the TO bearning. Lift up on that and you should be good. Quote
kuntzie Posted October 13, 2006 Author Report Posted October 13, 2006 Did you pull the slave cylinder off/ and or the plastic boot to remove the rod that attaches to the TO bearning. Lift up on that and you should be good. ya i did that, it still wont come apart, Quote
kuntzie Posted October 16, 2006 Author Report Posted October 16, 2006 Ever get it apart? ya i did today, found a hole in the tranny asweel, my clutch is indeed fucked though too.the whole reason why the trans wouldnt come out.... the splines on the clutch, they came apart from the disc itself, which explains everything, and the occassional slipping of the clutch when not punching it. the clutch is like heat cracked and shit, and its only got under 2800 miles on it hopefully with a new clutch my car wont break axles anymore (like only the last 1000 miles i had problems with axles) Quote
