kuntzie Posted October 14, 2006 Author Report Posted October 14, 2006 btw what brand of clutch are you running? i have a stage3 clutch, 2x plate and aluminum flywheel i am about to install tomorrow hopefully. stage 3... stock flywheel Quote
5speedz34 Posted October 15, 2006 Report Posted October 15, 2006 btw what brand of clutch are you running? i have a stage3 clutch, 2x plate and aluminum flywheel i am about to install tomorrow hopefully. Not the hijack, where did you get an aluminum flywheel? Quote
19Cutlass94 Posted October 15, 2006 Report Posted October 15, 2006 Heres one that I found. http://www.ultrarev.com/Fidanza_Aluminum_Flywheel_Oldsmobile_Cutlass_1988_1989_FWD_%288_lbs%29-p30295.html Although Im sure there are many different places to get them... Quote
5speedz34 Posted October 15, 2006 Report Posted October 15, 2006 Heres one that I found. http://www.ultrarev.com/Fidanza_Aluminum_Flywheel_Oldsmobile_Cutlass_1988_1989_FWD_%288_lbs%29-p30295.html Although Im sure there are many different places to get them... And thats for a 282. Quote
kuntzie Posted October 15, 2006 Author Report Posted October 15, 2006 im told its the same for all of them.... well fo suer all the 3.1s are the same Quote
dohcfiend Posted October 15, 2006 Report Posted October 15, 2006 hey kuntzie, what BRAND are/were you using for the stage 3 clutch?? cf, spec etc..?? also the stock replacements cost more than the aftermarket ones. i was looking at autozone. a ams one was $799 for a freaking clutch kit.. my clutchnet clutch and presure plate combined were not that much. 5spdz34. i bought mine from the fierostore. the 88 model fiero trannies(getrag 282) of that year and later are neutrally balanced just like the 284 flywheels. same tooth count, same diameter etc.. if u do get a 282 flywheel make sure it is neutrally balanced. i have been told all of them are 88 and up but my source was directly referring to the fiero ones and that is what i went with. Quote
kuntzie Posted October 17, 2006 Author Report Posted October 17, 2006 i was using a clutch from EZclutch off ebay.... while getting the tranny out, i did realizre there was a hloe where i didnt expect it to be, on the side of the housing.... so ya the trans is toast, all cosed by the shitty clutch, as it seemed a little funny to me since day one, but then again ive never had a stage 3 clutch before.... anyways the clutch pucks were like chipped and stuff and the splines or whatever on the center were loose, meaning my clutch was like slipping most likely alot- which would explain the axle issue as im told by many people. ive put another trans in now (a reman aswell) and hopefully this one holds up well, ive also went back to the stock clutch, as i just wanted to get it back together, and wanted to see how it holds up to the power now., not to mention if it doesnt hold up, he motor and trans are comming out this winter anyways so its no big deal. anyways- DONT BUY A EZclutch for a getrag 284... they told me that i was the 1st person to buy one from them (stage 3) for the 284. oh well they cant get them anymore as when i got it originally, they sent me the wrong dics and then again the wrong disc again ( it was right just the end wasnt machined for the release bearing to sit around it) nanyways had to get it machined and stuff.... they said they cant get me a clutch so im just getting a refund and going with the clutch my budy got as it is holding up great, from eurodrive i think it is, all custom made clutches and accessories Quote
5speedz34 Posted October 17, 2006 Report Posted October 17, 2006 Pics of the hole? I would use a Spec Clutch. Quote
dohcfiend Posted October 18, 2006 Report Posted October 18, 2006 whew, you had me worried for a sec. i was thinking "i hope it wasn't a clutchnet" . appreciate the info. thanx kuntzie. Quote
kuntzie Posted October 18, 2006 Author Report Posted October 18, 2006 dohcfiend check your pms i messaged you a little while ago Quote
dohcfiend Posted November 3, 2006 Report Posted November 3, 2006 i installed the clutch/plate and aluminum flywheel. quick question for you kuntzie, were your aftermarket clutches soft??? like it takes hardly any pressure to press the pedal down. there is no air in the line and it works perfectly, i suppose it is supposed to be "soft". what are your thoughts/experiences?? Quote
kuntzie Posted November 3, 2006 Author Report Posted November 3, 2006 mine sprung up very very fast, stiffer then stock to push aswell... do you have the stage 3 pressure plate aswell? Quote
dohcfiend Posted November 4, 2006 Report Posted November 4, 2006 sure do, it is a matching 2x pressure plate. Quote
kuntzie Posted November 5, 2006 Author Report Posted November 5, 2006 hmm wierd.. ya i dunno why its not stiff... ?? can you do nice chirps into ???3rd??? mine like to do them into 4th :twisted: prob why the trans took a shit though Quote
dohcfiend Posted November 6, 2006 Report Posted November 6, 2006 maybe just a break in thing b/c now i am noticing the pedal is tightening up some. Quote
