See, foam?
fastbird232
If I'm just sucking it through the vacuum line, do I still have to change the oil? I will not be putting it in the crank case, I just want to clean the intake and whatnot.
If you're not putting in the crankcase I dont think changing the oil would be necessary. Might be a good idea considering you will get some blow by, but I dont think it would be necessary.
The blow by was exactly my concern, but since I just changed the oil 500 miles ago, I didn't want to do it again. But this high idle problem is starting to bother me, and as far as I know, it's never been foamed in it's 178,000 mile life.
Maybe wait til its time for the next oil change to sea foam it? I've never sea foamed mine and its at 178k.
I would, but I can tell the weather likely won't hold out until then.
I changed the oil on my Sonoma and did Sea Foam right after the oil change.
The car smoked like a mother fucker! Thick gray smoke, my dad was like "owww man." The fucker barely started after that, and died multiple times after I took it out. I had to keep my foot on the pedal at some lights, till it finally calmed down.
Yeah, I need to change my plugs.
