FordBoy Posted October 5, 2006 Report Posted October 5, 2006 What is a HUD im thinking a new word for cluster but im lost here?? Quote
Regal_GS_1989 Posted October 5, 2006 Report Posted October 5, 2006 Heads Up Display. Basically, it Projects your speed, and some other info with newer HUD's, onto your windshield. Quote
Regal_GS_1989 Posted October 5, 2006 Report Posted October 5, 2006 Theres a 0 - 60 video i did with the cutlass the day i got it running. It's a little quicker now, But You can see the HUD in action Quote
FordBoy Posted October 5, 2006 Author Report Posted October 5, 2006 So its the speedo cluster then right? Quote
Regal_GS_1989 Posted October 5, 2006 Report Posted October 5, 2006 So its the speedo cluster then right? Not quite. You have the speedo in your cluster, than the HUD projects that onto the windshield. If you watch my video, you'll see that you can see the speedo(analog) and you can also see the speed on the windshield (Digital) The HUD is the digital one. On the first Gens, its a very prominent unit that sits on the dash right above the cluster. The unit on the dash above the cluster would be the HUD unit. Quote
FordBoy Posted October 5, 2006 Author Report Posted October 5, 2006 So its like a projector? not the speedo itself Quote
Psych0matt Posted October 5, 2006 Report Posted October 5, 2006 correct. its a seperate thing from the cluster that projects speedo and a few other things onto the windshield so you dont have to look all the way down at the cluster Quote
Regal_GS_1989 Posted October 5, 2006 Report Posted October 5, 2006 Yup. The 1st gen HUD's project Speed in MPH or KM/h, left and right turn signals, Check Guages, and the Grand Prix ones will display a low fuel light. The cutlass ones just use the check guages as the low fuel indicator. Quote
GP1138 Posted October 5, 2006 Report Posted October 5, 2006 Here's how it looks in my car. Note how in the newer models it's recessed into the dashboard. Actual picture of what you see. If you look closely, you can see the outline of the other info it can light up, like turn signals, gas/oil/battery dummy lights, etc. Quote
Psych0matt Posted October 5, 2006 Report Posted October 5, 2006 mine doesnt say check guages when i have low fuel factory wired, so i dont know Quote
jdcutty Posted October 8, 2006 Report Posted October 8, 2006 mine has a little gas pump thing that pops up when my low fuel light comes on. Speaking of, it's on right now. Quote
Psych0matt Posted October 8, 2006 Report Posted October 8, 2006 mine has a little gas pump thing that pops up when my low fuel light comes on. Speaking of, it's on right now. Ken was telling me that the cutlasses are wired different or something, cuz the gas pump lights up on the startup sequence, but thats all Quote
jdcutty Posted October 8, 2006 Report Posted October 8, 2006 hmmmm, thats weird. I guess it's prolly cause the check guages light comes on in the cutlass, as opposed to a low fuel light as in the GPs. Quote
digitaloutsider Posted October 9, 2006 Report Posted October 9, 2006 Here's the video I took of the HUD in my Bonneville: http://www.digitaloutsider.org/bonne060.mpg Quote
Crazy K Posted October 9, 2006 Report Posted October 9, 2006 mine doesnt say check guages when i have low fuel factory wired, so i dont know well............... you're car is bastardized!!!! the ub3 cluster (non-hud version) does not have the outputs to properly operate the HUD warning info. the HUD fuel warning light is diabled at least on the 92-94 CS, and the 91 is a discrepancy as to whether it is or not. by disabled.... it is basically not wired in. it would work if it was wired and had a proper feed line giving the correct signal.... properly, as in the GP, it lights and stays lit, at least for 30 seconds(or close to that). if tapped into the fuel line it flickers as the sender signal varies at the 10volt or availbe ground range Quote
Psych0matt Posted October 9, 2006 Report Posted October 9, 2006 that is the short version of what ken told me a week or so ago on the phone for like an hour Ken, when you coming back? Quote
97loudcut Posted October 9, 2006 Report Posted October 9, 2006 dont host threads with generic names. Quote
FordBoy Posted October 9, 2006 Author Report Posted October 9, 2006 shitWell i was wonder cause someone told me i had one and someone tod me bull shit u do. Now i know that i dont. Quote
