Regal_GS_1989 Posted October 3, 2006 Report Posted October 3, 2006 Does anyone know what exactly can trigger the check guages light on a 92 cutlass? I was driving it today and the light just came on. All of the guages were fine. If I would stop and restart the car, it would go out, and then it came on again like 5 minutes later. The only time that it has ever come on before is either when i have low fuel, or i hit the amber line on the tach. All the fluid levels are good, and the car still runs fine, except for what sounds like a noisy idler pulley But that's going to wait till next year for me to figure out. Quote
19Cutlass94 Posted October 3, 2006 Report Posted October 3, 2006 Only time mine has ever come on is when the gas was low, and my voltage was low ( damn alt! ) Quote
RJansen658 Posted October 3, 2006 Report Posted October 3, 2006 There a couple things that can trigger it IIRC. low oil pressure high temp low alternator output low fuel high rpms There may be more that I am missing... It sounds like a sensor is messing up just for a second.... IIRC it only has to sense low oil pressure for a moment and the light will illuminate until the next key cycle. I think it the same for all the triggers. Quote
skiiirt Posted October 3, 2006 Report Posted October 3, 2006 I've never seen my Check Gauges come on when I've had low oil pressure. In fact I've had 0 Oil pressure and it never turned on.. But then again, neither did the engine shortly after. As goes with the High Temp. I've been pretty high on the scale and never had any warning lights. Same with the low voltage. Never seen the check gauges come on when I've needed a boost. Now Low Fuel. That definately triggers check gauges. I personally think that's the purpose of the light Quote
rockfangd Posted October 3, 2006 Report Posted October 3, 2006 mine came on when my alternator went, when i ran out of gas and when my oil pressure was too low, i havent run it hot yet though so i hope that works lol, but i recently updated it to the ub3 cluster so they all have their own thing, oh yeah my 1994 cutty Quote
19Cutlass94 Posted October 3, 2006 Report Posted October 3, 2006 I've never seen my Check Gauges come on when I've had low oil pressure. In fact I've had 0 Oil pressure and it never turned on.. But then again, neither did the engine shortly after. As goes with the High Temp. I've been pretty high on the scale and never had any warning lights. Same with the low voltage. Never seen the check gauges come on when I've needed a boost. Now Low Fuel. That definately triggers check gauges. I personally think that's the purpose of the light I agree. The only time its come one for me was like I said when I was low on gas. When my alternator went, I had the x-mas tree on my dash. Every light that could have turned on did. But low fuel was only time Ive had it come on. Quote
Regal_GS_1989 Posted October 5, 2006 Author Report Posted October 5, 2006 I drove it all day after posting this, and it never came on again. The next day, it came on on 3 seperate occasions. I think tonight i will reset the ECM and see if that makes a difference. If not, I have a feeling that there may be an issue with the cluster itself. The car is only going to be on the road until the 18th, then the Regal is getting insured and the cutlass will be parked for the winter, so i guess i can live with it for a few more days. Quote
GutlessSupreme Posted October 5, 2006 Report Posted October 5, 2006 I've seen mine come on with low fuel and temp guaged in the red.. can't remember if it came on when I was having voltage problems. Quote
