Would this motor work in a w-body?
you could probably make it work if you had enough time.
--Dave.
--Dave.
Could, but it'd be pointless considering the 3100 makes the same HP and roughly the same torque.
the starter is on the opposite side for a FWD application, and the mounts are wrong. Its basicly the 3.4L from a camaro.
I would like to see a 4.3 motor dropped into a W. Cause then you could make a Ty/Sy sleeper...
no point..
Can you even put the upper end on the 60 degree W-body block?
Yep, sure can. Ask Pat for info.
