Raydee Posted September 30, 2006 Report Posted September 30, 2006 Both my tranny cooler lines are leaking on my Cutlass. I think I found the lines online at autozone for $43 for the upper and lower lines. This looks like a simple job even though I suck at mechanics. What is involved in changing the two lines? Quote
Robby1870 Posted September 30, 2006 Report Posted September 30, 2006 Where are they leaking from? Quote
THe_DeTAiL3R Posted September 30, 2006 Report Posted September 30, 2006 You can cut off the rusty areas and replace it with rubber hose and clamps. Did that on my dad's Lumina van, and the tranny oil cooler kit I got came with hose. Don't worry about it melting... it can take extreme heat!! Quote
Robby1870 Posted September 30, 2006 Report Posted September 30, 2006 Yeah, I recently had to do the same thing. That's why I was asking where the leak was. The rubber part of one of my lines started leaking. Quote
19Cutlass94 Posted September 30, 2006 Report Posted September 30, 2006 Mine was leaking, but a simple change of a hose clamp did the trick. But like said, it depends on where its leaking. Quote
Raydee Posted October 3, 2006 Author Report Posted October 3, 2006 Mine are both leaking right where they are clamped together at the frame. I didn't realize I could just cut the tubing and replace it with hose. I am sure its not the right way but it will get me by for now. Thanks for the replies! Quote
Stevo Posted October 3, 2006 Report Posted October 3, 2006 You can go overboard and replace the damaged sections with hydraulic hose but I just bought the actual lines and installed them myself. The top bolts on the trans cooler are a bitch. Quote
19Cutlass94 Posted October 3, 2006 Report Posted October 3, 2006 Ive found the clamps that GM uses for the hoses suck. Ive had to replace just about all of them with better clamps before I got the lines to stop leaking. That was about 2 years ago and I havent had a problem since. Quote
