Best bet is intrax springs from a fellow member that is selling or doesnt want them.
yea but intrax only sells springs for '97 and newer...will these springs fit in my '95?
so a '95-'99 montecarlo has the same setup as our cars? therefore we can get lowering springs from them? Will i need to replace my struts or can i just get the springs and put them in?
I am kind of looking for a complete set because the car will look silly just lowering the front
Guest TurboSedan
only the '95-'99 Monte Carlo front springs will work on your car. for the rear you can get adjustable coilovers (FFP or Held Motorsports) or a lowering leaf spring (FAF or Birchmount).
so basically our older cars are scrwed. We can't just buy new lowering springs like the 97 and newer cars we have to go with coil overs and stuff?
for the front you can buy Intrax or Suspension Techniques (discontinued)
for the back you can buy FFP coilovers, Birchmount metal leaf, Flexaform fiberglass leaf, or put a big stereo in your trunk :lol:
Ohh is intrax the old suspension techniques? Are you talking about leaf springs for the rear?
They are different springs all together, Intrax is a progressive rate spring while ST is just a regular spring.
Yes, the Birchmount and FAF are leaf springs for the rear, they replace the stock factory fiberglass leaf spring.
this topic will never die. i bet there are 25 pages worth if you use the search feature
wow i didn't know my '95 GTP came with leaf springs in the rear
not leaf springs....leaf SPRING. it still has struts in the back too
Just wanted to add that "Transverse" means that the component is mounted "East-West" (left to right) as opposed to "Longitudinal" ("North-South" or front to back.) Monoleaf means single leaf, so a Transverse Monoleaf literally means a single leaf spring sitting in a left to right configuration.
Take a peek underneath the rear of your car and you'll get the picture...
i tried looking for it and maybe i am just blind...where abouts in the rear is it? anyone got a pic pointing to it?
i see now! Nice so are these guys easy to take out or is it total disassemble?
