my 95 cutlass brake lights don't work. My third brake light, turns signals and flashers all work, but not brake lights. I replaced the brake switch an no luck, also check all connections in the trunk with similar results. Any one have any experience with this problem?
Turn Signal switch in the steering column..
If you don't have an airbag, it's a really simple replacement, but having an airbag complicates it much more.
Airbag is not really that bad. The airbag shouldn't go off if you pull the ARBG fuse and also unplug the yellow airbag connector under the dash.
Once you get the airbag off, the steering wheel comes off same as a regular one. I haven't actually had to replace the switch on mine, so I'm not sure how much trouble the SIR coil and other stuff will be though... it might not even be in the way, I'm not sure.
