ok, so i finally finished replacing the 60e in ym mom's lumina. background: replacement trans is from a 93 gp. perfect working condition last time car was driven.
so, i put some fluid in and took the car for a test drive. i only have 2nd gear. wtf? low fluid wouldn't limit the car only to second gear, right? also, although the transmission is electronic, it should still start in first and shift to third after a certain rpm, yes? i was thinking maybe the wiring changed a bit between 93 and 95 and the trans was engaging 2nd gear start. however, since it wouldn't shift out of 2nd into 3rd, i dismissed that theory, too.
so, anyone have any ideas?
I know the valve bodies between '91-93 and '94-97 are different. I think even the solenoid setup is different too. Either way, it's not interchangeable. Starting in 2nd gear could mean the "A" solenoid is not getting power. Can you get it to 4th gear? I do have the wiring pinouts ID/function I can give you from my '95 Service manual, however you'll need to locate '93 wiring specs somewhere as I don't have any book for that year. This way you can see what's different at least with the inputs to the tranny solenoids. Let me know if you want it.
yeah, send it my way. i can get the 93 diagrams. i'll just repin the connectors and i'll be good. hopefully, anyhow
and no, only gears it has are reverse and 2nd
A- Lt Grn ckt 1222 Shift Sol A
B- Yel/Blk 1223 Solenoid B
C- Brn 418 TCC PWM Solenoid (your '93 does not have this solenoid)
D- Tan/Blk 422 TCC enable solenoid (you DO have this solenoid)
E- Brn ckt 441 +12V from u/h elec center for pwr all sol
F- +5v for temp sensor if equipped
G- Signal for Temp sensor if equipped
do that, itll work if you wire it right. i had the same issue when putting 91 tranny in 94, except i only had 3rd and 4th until i reqired the plug.
here's the closest diagram i can find. everything matches except for pin a on the connector. on the 93 harness, pin a is purple.
helpme out a bit, guys. i don't want to rewire this and it be worng.
well, on the '95, pinouts A.b,c,d are outputs from the tranny solenoids to the PCM (grounds). C is for the PWM solenoid which you don't have so that's out. So you'll just have a total of 5 wires in your connector. It looks like "E" is ok. "A" wire (assuming you are modifying the '95 plug) needs to be moved to F. B wire needs to go to position G. D is ok. I don't know what you need to do with the switches, I would guess keep them disconnected as that was for the old style PCM. '95 TCC solenoid shares power feed INSIDE the tranny with he other solenoids, not separate like in '93. Therefore you need to install a wire into "A" and SPLICE this into "E". ; B and C will be empty since those switches are not used.
no worries, guys. i rewired the plug and i have all 4 forward gears. i still need to add fluid, but other than that i'm done.
thanks a ton for your help.
:lol:yeah, i wish i hadn't had to do this swap. oh well, thanks again for the help :biggrin:
