97loudcut Posted September 20, 2006 Report Posted September 20, 2006 My roomates 3.4 Cutlass won't start She said when she goes to turn it on it makes noise but not like it wants to turn over. They tried jumping it and that did not work. Quote
White93z34 Posted September 20, 2006 Report Posted September 20, 2006 i'm going with bad starter, till more information. Quote
97loudcut Posted September 20, 2006 Author Report Posted September 20, 2006 yeah thats all i know so far Quote
Psych0matt Posted September 20, 2006 Report Posted September 20, 2006 does the solenoid click? or does it just not want to turn over even though it engages? Quote
JakeMetz63 Posted September 20, 2006 Report Posted September 20, 2006 Ran it low on oil because of the O-ring leak, go ahead and swap in a new engine. Starter or disconnected cables would be my best guess. Quote
Brian P Posted September 20, 2006 Report Posted September 20, 2006 "it makes noise" kay. Not enough info Quote
97loudcut Posted September 20, 2006 Author Report Posted September 20, 2006 well its a girl relaying the info to me she said "no clicking when I go to start it" so prolly not solenioid Quote
Brian P Posted September 20, 2006 Report Posted September 20, 2006 well its a girl relaying the info to me she said "no clicking when I go to start it" so prolly not solenioid True....it's usually "I turn key no clickie no startie!" Without remembering the year, if it's a '94-95 check the Pass-key chip on the ign key, heck if there's a spare key, use it. Quote
5speedz34 Posted September 20, 2006 Report Posted September 20, 2006 well its a girl relaying the info to me she said "no clicking when I go to start it" so prolly not solenioid True....it's usually "I turn key no clickie no startie!" Without remembering the year, if it's a '94-95 check the Pass-key chip on the ign key, heck if there's a spare key, use it. It's a 93. Matt if you went out and tried to jump it, how could you not hear what sound its making? I'm going with dead battery. Quote
Regal_GS_1989 Posted September 21, 2006 Report Posted September 21, 2006 Check the aux post and all the other connections around the battery. I've seen a few cars that have power, but die off completely and make no noise when trying to start. If all that checks out, and it still doesnt start, then try a different battery. Quote
JakeMetz63 Posted September 21, 2006 Report Posted September 21, 2006 Smack her then tell her to put it into park. Quote
jdcutty Posted September 22, 2006 Report Posted September 22, 2006 Smack her then tell her to put it into park. I would go with a loose cable on the starter or a loose ground cable. Quote
SigEpCutlass Posted September 22, 2006 Report Posted September 22, 2006 Did you use the aux post to try and jump it or did you use the terminals on the battery? I'm willing to bet you the aux post went bad or it's ground is corroded. I had to replace mine for the same reason after I couldn't get my car jumped from it one time. Otherwise, if you can't jump it from the battery directly, then I would say that there is a problem with either the starter or the alternator (depending on what if any noise the solenoid makes). Quote
