Easiest connection to measure VACUUM???
I just bought a nice vacuum gauge set and I want to do a vacuum check on my 89 Supreme's 2.8L engine.
Where is the easiest/best hose connection to do so? I was thinking of using the hose that connects to the MAP sensor? Would this be OK?
As far as I believe, our engines should produce about 20" HG vacuum at idle, correct? Give or take...
Is the PCV valve location a good place to measure vacuum at all?
THANKS!:)
