Is it possible to take apart 94-96 GP Fog Lights to clean them?
Well, I noticed the problem when I blew a fog light. Some how water is getting in the fog lights. Anyways, I took them off and notice how really dirty they are on the inside. I tried taking them apart from the sides, but it doesnt work. I dont really want to break the seal. Cause it does hold water in there. Also is there anyway to prevent the water from getting in? The only way it looks like its getting in is throught the hole where you insert the bulb.
Thanks!
Close up of it.
With flash off.
The hole I think where water is coming in:
Do you think CLR would clean them?
inside?....i dunno, i didn't clean my inside....they wern't bad.
well clr did help a little. I think I'll just try and find some new ones or get some aftermarket ones like gtp munky's.
*I think* they are the same from 94-03.
OMFG. I didnt even think of that!
i'm sure they are a generic design that GM has used for awhile, bonnievilles should have them too, and hell prety much any newer GM car with those style lights.
Why not just install an aftermarkt kit? then you could wire it up seperately and have your fogs on at all times, all you gotta do is make sure you get the correct size bulbs, too big won't fit too small will look goofy!
Jamie
screw that get the aftermarket blue ones and wire them to your factory switches.
same thing I did and I love them
$20 mod
Where do I get these? As long as they will still be able to use my Silver Stars in there.
im taling the PILOT round lights that are sold at Autozone or murrays...but your in canada so whatever your autoparts store is up there
Probably Canadian Tire.
I think it would be a good mod so long as it didn't look to tacky.
So Canadian Tire's will look tacky? Hmmm... Any links to them?
Oh and yes newwer 97+ GP's use the same fog lights.
can't take them apart....I tried when i was polishing them.....
when who polished them? lol ha ha ha ha....i made my first post on here in who knows how long. :)
either way...good luck getting inside there.
I'm assuming you helped Adam with his car? And about time you showed back up!
Hi Zach.
i said that to get your lazy butt ot post.....LOL
eerrrrr....sorry for not giving you credit. :leaving:
