So lately as I'm driving I've been hearing a sort of flapping sound coming from the back end of my car. It stops when the car stops and speeds up as I go faster. Just wondering what it is..
Thanks
are you sure you dont have a cat with its tail caught in the wheel, flipping and hitting the ground with it's face every time the wheel goes around once?
Have you have any body parts off as of late?
If not I would look for loose weather stripping.
Well to me it sounds like it's coming from under the car.. somewhere near the back wheels.
i had a bunch of small rope wrapped around my axle at one point this spring (from holding my cover down) that made a similar sound, anything like that?
get under your car and start looking for something foriegn or loose. Maybe a shifted belt in a tire???
Are you sure it's not a noise coming from a bad wheel bearing then? I have my tires perfectly mounted/balanced & I have a similar noise coming from a bad wheel bearing. Too bad you can just replace the bearing, but you have to replace the entire hub assembly. :(
Already did that..
And wheel bearing eh? I didn't know it made that kind of sound but I'll check it out. Thanks!
i actually had one of my wheels come loose on my cutlass...made a sound that almost sounded like the brakes were messed up, but it didnt change if i was hitting the brakes or not...i pulled over on the side of the road and wanted to pull the wheel off to see if i could figure out what was wrong, and when i went to take it off, i realized it was really loose...sooo, you may wanna just confirm all your lugnuts are tight...also, is it possible you have something stuck in one of your trim rings?...
Do you feel the vibration? For me, somehow I snapped both of my rear sway bars clamps. They were rusted out and all crappy. I finally got my camera back today, so I can update my thread and show you.
I'll add to the list- bad radial belt in tire. I've had it happen. Thump thump thump almost like a flat tire... changes at different speeds.
Well, if that was the case she should feel it too.
