1991 Cutlass International Sedan Help with brake lights and fans
New to w-bodies :need help with 91 cutlass international
  1. 1. New to w-bodies :need help with 91 cutlass international
    • Brake lights
    • cooling fans
      0
I just bought a 1991 Cutlass Supreme International sedan 3.4. The brake lights will not go off, and the cooling fans will not turn on.These are the 2 major problems,but I am sure I will have more. The car looks great and runs great. I think I got a steal. I believe it has every opt. out there. I only paid $700.00.I hope someone can help.
What's up with the poll? I'm not totally sure, but regardless be sure to use the search function before you post.
Does this car have the POWERMASTER? a non vacuum booster operated brake system?
if so I'll give you $50 for it :willynilly:
Look for a brass sensor located by the thermostat. It is the sensor that tells the pcm the engine temp. the PCM controls the fans. if it doubt, replace it. (I always do)
must have pic, then help you figure out the problems later lol :biggrin:
ditto! photobucket.com can host.
