dohc v6 Posted September 13, 2006 Report Posted September 13, 2006 Ok I relocated my battery to the back and am have some trouble. Not with the moving of the battery, getting the car to start. I am using 4 ga wire from the positive terminal where it used to connect to the battery and the ground 4ga to the strut tower. I started the car 3 times and fine and the 4th it would barly start, I mean barly. what did i do wrong. I understand I need to clean it up but first what do i need to do to fix it. [attachment deleted by admin] Removed to free up storage space. Quote
dohc v6 Posted September 14, 2006 Author Report Posted September 14, 2006 Just check the voltage and its at 13.5 or so from the post all the way to the back where the battery is. now it will start when its cold just has very hard time and sometimes does not start when warm Quote
slick Posted September 14, 2006 Report Posted September 14, 2006 Might just be your starter or starter solenoid going out. I've had similar problems in the past. Quote
dohc v6 Posted September 14, 2006 Author Report Posted September 14, 2006 I think that exactly it. how hard is it to replace on the 3.4 Quote
slick Posted September 14, 2006 Report Posted September 14, 2006 I think that exactly it. how hard is it to replace on the 3.4 Not hard at all. You may have oil cooler lines in the way, but with enough muscle, you can move those out of the way. Quote
dohc v6 Posted September 14, 2006 Author Report Posted September 14, 2006 no oil cooler on the 94. that suck for me, but in this situation it wont haha I love 94. Ok i know how to diconnect the wires how do i get the solinoid out of the housing. any tricks. also I have to hold my foot on the gas to start the car with the battery in the front. and with out doing that it take 3-4 cranks to start. Its the solinoid Quote
slick Posted September 14, 2006 Report Posted September 14, 2006 I would just replace the whole thing. In fact, get one from a 2000+ 3100/3400 equipped vehicle. The starter is a bit smaller and lighter weight. Quote
dohc v6 Posted September 14, 2006 Author Report Posted September 14, 2006 I think a solinoid is 20 bucks. I will replace it and When i drop my new motor in I will drop in a new starter. whats the deal with the new starters, are they exactly the same. no modifications to make work. Quote
slick Posted September 14, 2006 Report Posted September 14, 2006 No modifications, bolt right up. Smaller, lighter, and they are either gear reduction or high torque. I forget which they are(or maybe both). There has been a few topics on this in the past. A quick search(don't use the search function, it blows, just click back pages in the performance section) should yield a few topics. Quote
dohc v6 Posted September 14, 2006 Author Report Posted September 14, 2006 damn thank for the heads up. I will do that for sure Quote
Psych0matt Posted September 14, 2006 Report Posted September 14, 2006 I put one of those on when i did my swap. bolts up exactly, and i think it sounds better too. doesnt have the same weak-bear growl, more of a strong-squirrell sound. yeah, that made no sense, but it sounds more modern and up to date if you will. Quote
dohc v6 Posted September 15, 2006 Author Report Posted September 15, 2006 Well it is still doing it. Any other ideas. PLease help I need to fix thiss tonight Quote
dohc v6 Posted September 15, 2006 Author Report Posted September 15, 2006 I got 12 volt to the starter, is this good or bad. what should I be getting with the car off. Quote
dohc v6 Posted September 16, 2006 Author Report Posted September 16, 2006 I REALLY HAVE NO IDEA. PLEASE HELP ME Quote
Turbo231 Posted September 16, 2006 Report Posted September 16, 2006 Hello, I'm sure you've covered the basics...like your battery is good. Say it is, just having a body ground might not be enough for your car. My Buick has the battery ground right to the engine block and the positive right to the starter. The actual body ground is a very thin wire...good for accessories, but not much else. My engine ground failed one time, and while the car would turn over, it was very weak...come to find out, it was using the little body ground wire, which would get very warm and the more I used it, the slower it would start. Long story short, try a better ground. Quote
dohc v6 Posted September 16, 2006 Author Report Posted September 16, 2006 So should I change the ground in the trunk or add a ground from the starter to the body in the engine bay. I dont think I can put a 2g wire from the starter to the body. But why would it work when its cold and not hot. Quote
slick Posted September 16, 2006 Report Posted September 16, 2006 Did you replace the whole starter/solenoid combination or just the solenoid? Quote
patgizz Posted September 17, 2006 Report Posted September 17, 2006 the engine ground stud is one of the tranny bellhousing bolts, not on the starter Quote
dohc v6 Posted September 17, 2006 Author Report Posted September 17, 2006 so what are you saying Quote
AWeb80 Posted September 17, 2006 Report Posted September 17, 2006 when i put my battery in the trunk, i left the original wires there and hooked the positive from the trunk to the remote terminal in the engine bay. I then have two grounds on the battery, so I wired both of those to the frame in thte trunk. Its kinda a mess, but, i've since cleaned it up. http://smg.photobucket.com/albums/v639/AWeb/Battery%20Relocation%20and%20Fender%20Well%20Intake/ Quote
dohc v6 Posted September 17, 2006 Author Report Posted September 17, 2006 well i ran two grounds 4ga to the strut tower in the back from the battery and a ground strap from the fraim rail to the tranny bellhousing. It sees to have fixed the problem-4 starts and all is good hopefully it starts tomorrow after class gets out Quote
dohc v6 Posted September 17, 2006 Author Report Posted September 17, 2006 please let me build you an intake for that thing. No offense but that looks like it could use a little touch up. If you send that to me I will make you an exact match, in all aluminum polished piping and silicone couplers. Any body else need one for that year and motor? It will look like this [attachment deleted by admin] Removed to free up storage space. Quote
AWeb80 Posted September 17, 2006 Report Posted September 17, 2006 LOL, my intake is better now. http://smg.photobucket.com/albums/v639/AWeb/CAI%20Pics/ Quote
dohc v6 Posted September 17, 2006 Author Report Posted September 17, 2006 My offer still stands. It looks good but does it do anything. Also with that rubber 45* it will deterioriate in less then 6 months. Unless it is marine butal rubber. Let me know and seriously not trying to be a dick its just you have a set up that I can duplicate for a lot of people. Quote
