HELP anyone know how much this hose is going to cost?
Holly jesus this is rediculous a simple radiator install and some other things and its taken two days !
im no mechanic but at least i can do some things, now i justgot EVERYTHING back together and put the coolant in, what a LOVELY process, and just to gind a new COOLANT LEAK :) yay !
so yea this one reallllllly sucks because its coming out of an expensive looking hose
anyone has any idea how much these things cost? my brother says 150 but thats redic
its the pipe in the red cirlce, goes from rubber to metal off the heater core?
thanks in advance, this really sucks because i need my car badly and with this super cool leak now i cant go no where :(
If it is the heater hose, then it is gonna be around 80 bucks and it's a dealer only item. However you can just cut the metal hose where it is leaking, cover it with some rubber hose and clamp it on each side. Cheap and easy fix.
i've done that repair quite a few times now, works great.
how hard is this mofo to pull out? do i have to push the engine foward? if i buy a new hose how long is it? ih eard it goes all the way around the rear of the engine and through the firewallll??????
if its really hard to take out and install i'll probally try a cheap fix if i can manage to do it without pulling the hose out the car, the leak is right near the CV shaft from the tranny, and it leaks onto the a arm of the passenger side and onto the ground
Why don't you just go to your local parts yard and find one in good condition and just swap it? That'd save you a lot of $$$ if it's a dealer only item!
even better i cut the bastard at the firewall and ran a heater hose from there directly to the water pump now it works great ! oly 4 bucks ! :)
I just changed my heatercore.... and I changed both rubber hoses with bulk hose which cost me like $4 for 3ft. The stock bottem hose of the heatercore was a bitch to remove, so I simply slit it with a knife and tossed it. I put the stock upper hose back on, however it was rubbing against the EGR or O2 sensor thing (hot) and burned a hole in it. That was fun, steam everywhere and it still stinks now when I put the heat on. I replaced that hose then as well, so just be careful you keep the rubber hoses away from anything hot!
I did the exact same thing this spring. Pull the wheel off, unbutton the rubber dirt guards, hacksaw the damaged parts off, and clamp some new hose on there. Works like a charm!
yea thats what i was going to do, but my hose fix goes formt he firewall over the shock tower under the brace thing over the washer bottle and to the puimp, not in the way or touching anything moving or making anything hot so its pretty nice just dosnt look to nice but idc i just gotta drive the car until the swap
i replaced the pipe. just had to rock the motor forward like doing the rear plugs. cost about $43 at the dealer. worst part is getting the hose off the heater core.
Fix one leak and the next weakest link will show itself soon afterwards.
yea i learned that one =/
43 dollars?
what assholes ! they wanted 153 when i called LOL such assrapers i should walk in the dealership with my pants down and myself bent over so i can get the assraping over with quickly
well the hose i bootlegged is working very well, the orig crpa is leaking in like 3 diff places under the car so i said screw trying to patch it up and reinstalling a new one for 153 bucks and rokcing the engine looked hella bitchy so thats why i didnt bother =/
shit if that isan't the truth, i did that for a year on my camaro.
