wreckless123 Posted September 12, 2006 Report Share Posted September 12, 2006 My cruise works half the time. Sometimes for hours at a time and then just quit? From reading here, there is possiable a corroded ground to the CC box. Could someone help me find the CC box and were the ground is located that I am looking for. Pictures would really help.. Thanks for any help in advance.. Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted September 12, 2006 Report Share Posted September 12, 2006 The cruise module is attached to the driver's side strut tower, and on the 91's, it should have a large rubber diaphragm on the outside of it, and will also have a vacuum line connected. In the vicinity of the battery, check the condition of the vacuum lines and the 3-way check valve. Check the vacuum canister under the driver's side fender (near the bumper) for any cracks or broken vacuum line. There's also a cable running from the module to the throttle body, so if you ever need to hunt down a cruise module on another car, that's the surefire way to find it. Quote Link to comment Share on other sites More sharing options...
wreckless123 Posted September 12, 2006 Author Report Share Posted September 12, 2006 Do you think it could be a vacume leak? I figured electrical since I have cruise intermitently.. Quote Link to comment Share on other sites More sharing options...
Crazy K Posted September 13, 2006 Report Share Posted September 13, 2006 check it out. it may be a line that wiggles and leaks sometimes. Quote Link to comment Share on other sites More sharing options...
wreckless123 Posted September 13, 2006 Author Report Share Posted September 13, 2006 Thanks I will give it a look.. Quote Link to comment Share on other sites More sharing options...
