GutlessSupreme Posted September 12, 2006 Report Posted September 12, 2006 I have classes downcity two nights a week now and I've been pulling my ECM fuse for some cheap reassurance before I leave it anywhere. Does that, in effect, make it need to relearn the idle/etc everytime I pull it? Would I be better off rigging up a switch to the fuel pump? Quote
Brian P Posted September 12, 2006 Report Posted September 12, 2006 which fuse are you pulling? The one under the hood, or inside the car? Quote
GutlessSupreme Posted September 12, 2006 Author Report Posted September 12, 2006 Inside. Glove box fuse panel. Quote
White93z34 Posted September 12, 2006 Report Posted September 12, 2006 doubt it makes much difference i'm sure the car has to relearn some values, but by the time you get home, i'm sure its relearned all it needs to. Quote
Brian P Posted September 12, 2006 Report Posted September 12, 2006 just going off the top of my head, that interior fuse is just for the "hot in run" lead to the PCM, so you shouldn't be losing any memory. Quote
5speedz34 Posted September 13, 2006 Report Posted September 13, 2006 I have classes downcity two nights a week now and I've been pulling my ECM fuse for some cheap reassurance before I leave it anywhere. Does that, in effect, make it need to relearn the idle/etc everytime I pull it? Would I be better off rigging up a switch to the fuel pump? I'm assuming this is on the Cutlass? Put full coverage on it and collect your $1000. Quote
GutlessSupreme Posted September 13, 2006 Author Report Posted September 13, 2006 Put full coverage on it and collect your $1000. Please. I already pay double that a year for liability. The STE will be considered though, after all the money and time I've dumped into it... just going off the top of my head, that interior fuse is just for the "hot in run" lead to the PCM, so you shouldn't be losing any memory. good to hear. thanks Quote
