94CutlassXtreme Posted September 10, 2006 Report Posted September 10, 2006 I noticed the headunit is a Delco unit in my GTP, could I install my Pioneer out of the Cutlass and have it work OK with the Bose speakers? Quote
19Cutlass94 Posted September 10, 2006 Report Posted September 10, 2006 Youll need the adapter ( harness ) for that HU for that car. Other than the dash kit. those two things and youll have no problem. Quote
94CutlassSLCoupe Posted September 10, 2006 Report Posted September 10, 2006 do you have a HU with a wired remote input so you can keep the steering wheel radio controls? Quote
Cam'ron Posted September 10, 2006 Report Posted September 10, 2006 If you want the steering wheel controls... isnt the stock radio removal a bigger issue because of hte RKE and shit that is in the facotry radios Quote
19Cutlass94 Posted September 10, 2006 Report Posted September 10, 2006 No, if you search for it you can find a device that will let you keep your steering wheel controls with an after market HU. I dont know exactly what it is, as Ive never had to deal with it. Quote
Cam'ron Posted September 10, 2006 Report Posted September 10, 2006 yeah so it is that... whatever it is called, the harness adapter and an install kit and you should be good... unless you just mount your stock HU in the trunk or somewhere Quote
BCM Posted September 11, 2006 Report Posted September 11, 2006 http://www.zzperformance.com/grand_prix/products1.php?id=294 That should let you be able to use your steering wheel controls with that h/u Quote
runt Posted September 11, 2006 Report Posted September 11, 2006 http://www.zzperformance.com/grand_prix/products1.php?id=294 That should let you be able to use your steering wheel controls with that h/u  Yes, that'll let you keep your SWRC.  You shoudln't have a problem with the RKE. I believe that type of programming didn't hit the W cars, but N bodies and the like. Quote
GP1138 Posted September 11, 2006 Report Posted September 11, 2006 I don't think RKE and security system shit was moved into the HU until the '04 GP's. Quote
DiscoStudd Posted September 11, 2006 Report Posted September 11, 2006 I don't think RKE and security system shit was moved into the HU until the '04 GP's. The only Pre-04 W's that used the headunit to change the "convenience" settings were the 00-up Monte and Impala. Even if your car had that type of headunit, all you'd need to do is set everything where you wanted it before removing the HU (then install an aftermarket chime module because you'd lose the chime function after removing the stock HU.) I did exactly that in my Impala, and everything still functions normally. Here's a module that's plug-n-play with the GM steering wheel controls and Pioneer HU's: http://cgi.ebay.com/PAC-SWI-PS-Pioneer-Steering-Wheel-Remote-AVIC-N2-N3-D2_W0QQitemZ190030241670QQihZ009QQcategoryZ60208QQssPageNameZWDVWQQrdZ1QQcmdZViewItem  http://search.ebay.com/SWI-PS_W0QQfromZR40QQsatitleZSWIQ2dPS Quote
fastbird232 Posted September 14, 2006 Report Posted September 14, 2006 Wait... the same adapter from the '95 GTP works just fine in my '00 Grand Am. Why wouldn't the one from his '94 Cutty work in a '00 GTP? Quote
terryk2003 Posted September 14, 2006 Report Posted September 14, 2006 FWIW: you will lose your radio station display in your HUD if you switch to the aftermarket HU Quote
19Cutlass94 Posted September 14, 2006 Report Posted September 14, 2006 Thats not big deal. I dont have a HUD but still I cant imagine that being a huge problem. Quote
sl3196 Posted September 16, 2006 Report Posted September 16, 2006 Youll need the adapter ( harness ) for that HU for that car. Other than the dash kit. those two things and youll have no problem. Won't work. You'll either need to wire around the bose or some guys on clubgp splice rca cables in somehow to keep the bose. Personally I think the bose sucks ass so I wired around it. Quote
